HOME-MADE DOODLEBUG/TRACTOR PROJECT
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #1
Waldon52
Michigan , usa
John Deere
I was asked to start a new thread for this project to be sure people might see it is a new project.
You can see a series of pics as I took my walk behind snowblower and converted it into a riding doodlebug /tractor . The blade will come off for the summer and just use it to putter around with the grandson. I have 9 garden tractors and I now I am going to count this one as number 10 :laughing:
The latest progress picture shows the front fenders on and side covers and a hood over the engine . Also duel exhaust because I know chicks like those :thumbsup:
You can also see today I started building two storage boxes on each side of the seat.
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #3
Great project.
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #4
:thumbsup:
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #5
So, it looks like the back part you can hook up to anything, and it's like a trailer/surrey to pull around a passenger. Then when you hook it up to the snow blower, you have a front drive articulating tractor. I just love this latest project of yours!
Thanks ,
Yes , the rear can be hooked behind my garden tractors for my grandson to ride on . I would not have the rear section hooked on for plowing snow either. I will remove the blade for summer and just putter around the yard looking cool:laughing:
Today I worked on the front of the hood and boxed it in and remounted the headlights inside . This should increase my top speed :thumbsup:
I also attached the exhaust stacks and made a little hood ornament :confused2:aaahood.jpg
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #7
Cool project! How much does the back half weigh?
Thanks ,
The back weighs around 100 lbs. Then add my weight on the seat at another 100 lbs, :laughing:
Just move the handlebars side to side to steer it. Kinda crude but should be fun to ride around a tractor show on it.
Today I am grinding the welds and applying body filler to the welded seams. aaabondohood.jpg
aaapaint.jpgTodays progress picture shows it now green . After a few days I will sand and buff out the paint . then I will paint a yellow stripe on the side . It is slowly taking shape. You can see the t-handle and the steering wheel for my little grandson . They can be removed when hooking up both units together.
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #11
YEAH BABY! :D
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #12
Neat...have you built a Sherman tank yet? Best not as that might lead to a B-29.
Thanks ,
No tank yet but I have spent a few hours looking at how they build them . I think I could do it :thumbsup:
Todays progress I decided to use the two tri-rib tires I bought 2 years ago at the Walloon Lake Steam Show.
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #14
Thanks ,
I am building a narrow front swivel system for it . View attachment 369316
I think Waldon that if you wanted to, you could fab up a sheet metal nuclear reactor with your skills.
aaalight.jpgNo Nuclear reactor projects ha,ha.
Today I worked on the front section sheetmetal and boxed in a 3rd light on the front nose. I should get it all roughed in tomorrow and then next will be the last step to build the hitch that will connect them together .
Todays progress shows the sanding and painting done on the narrow front nose. 8 bolts and the front comes right off and the snowblade goes back on for winter use. Once I get the hitch made I may remove the narrow front and just build a cute normal bumper on front:confused2:aaadoodlebugnarrow.jpg
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #17
Nice progress Waldon!
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #18
Very neat build. You could always build a mini combine head for the front
/ HOME-MADE DOODLEBUG/TRACTOR PROJECT #19
Todays progress shows the sanding and painting done on the narrow front nose. 8 bolts and the front comes right off and the snowblade goes back on for winter use. Once I get the hitch made I may remove the narrow front and just build a cute normal bumper on front:confused2:View attachment 369746
I have to ask Waldon but in this picture you took of your "buggy", behind you and hanging on the wall is a picture of a large excavator shovel. I was wondering what this is. Thanks
Thanks ,
The big mining shovel in the picture on the wall is a 33 yard Terax rh-200 . I got to actually operate it and it was one of the machines I built a model of one similar to it.
Been gone on vacation and got back to welding in the shop again yesterday . Todays progress picture shows the hitch and the steering wheel done. I took some 1/4 inch steel plate and cut out the parts with the Plasma Cutter. The steering wheel was just a added touch for more confusion:confused2:
I should get the yellow stripes painted on this week and finish the project and take it for a test drive.
now I am finishing the fender mounted storage boxes.
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
2020 Nissan Murano SUV (A66738)
2020 Nissan Murano...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
Generator (A64553)
Generator (A64553)
