info on avery tractor
/ info on avery tractor #1
bcinlittleaxe
Member
little axe,ok
mahindra 4500
I just inherited a 1946 avery model a tractor that's been in the family since the day it rolled off the lot. I was hoping that some you guys could point me to web sites where I can find out more info on it and a place where I can find tires and wheels to fit. the motor will run but I have a lot of work to do to get it back in shape. any help would be appreciated
/ info on avery tractor #2
BC you may have better luck with this question in the "Vintage Tractor" forum. Go to "Related equipment" and scroll down to "Vintage tractors" and plop it in there.
/ info on avery tractor #4
Tractordata.com has some info about Avery tractors. Don't know which model you have but check there.
You can check with Miller Tire if you know the size you need. Miller Tire is a member here. Wheels might be a little harder to find. If you can figure out the bolt pattern spacing you might be able to use similar wheels from a different tractor that fit the bolt pattern.
/ info on avery tractor #5
Welcome to TBN. Join the fun.
My 1951 Minneapolis Moline BF tractor is actually a B.F. (Benjamin Franklin) Avery model R. MM bought Avery in 1950 and since MM already had a model R in its lineup, the Avery model was changed to BF.
Your A has a 4-cyl Hercules engine. It probably is the same model as mine (IXB3SL). You can get parts from Hercano Propulsion
HERCULES ENGINES OR HERCULES PARTS
Steiner Tractor parts has the bolt-on parts (carburetor repair kits, filters, switches, dashboard stuff, etc).
New Restoration Parts For Antique Tractors | Buy Vintage Tractor Parts
My engine was shot (no compression in any of the cylinders). A complete rebuild ($800 parts, $800 labor) was needed.
I'm nearly finished with the restoration. Need to install the hydraulics and do a little more on the wiring.
Good luck
Any tire dealer that handles the farm market will have tires and wheels to fit your Avery.
2017 Hyundai Trailer (A62613)
2017 Hyundai...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
Boomless Sprayer (A64127)
Boomless Sprayer...
2012 FORD SERVICE TRUCK (INOPERABLE) (A65643)
2012 FORD SERVICE...
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
