Interlocks on BX24
/ Interlocks on BX24 #1
easternhunter
Member
Charleston, WV
Kubota BX24
OK Guys,
I have a "new to me" BX24 that arrived Christmas time. Has been stored under the overhang roof of a single row stable this winter. Never sees any direct rain or snow.
Started and used it a month or so ago. Initially started fine. Toward the end, for some reason it got shut down and then was a pig to restart ... no reaction until I wiggled levers around some.
Tried to start it today ... and again ... everything did fine until it was time to turn over the engine ... and then NOTHING at all.
I suspect an interlock. I understand that there are three: 1) Seat occupied 2) in neutral and 3) PTO not engaged.
Is there a rational way to test which (if any) of the interlocks is failing?
Thanks,
Mike
/ Interlocks on BX24 #2
Mike I could start mine with out being in the seat. It is usually the pto mess with the pto levers
/ Interlocks on BX24 #3
I've had a problems with the seat switch on both my tractors. To defeat the seat switch jump the to leads with a piece of wire, this will eliminate one of your possible problems.
/ Interlocks on BX24 #7
I bought mine April 2011. Ron
Mine was purchased in September of 2012. Come to. Think of it, my previous BX 2200 didn't have that either. I wonder if it's a local thing.
Sent from my iPad using TractorByNet
/ Interlocks on BX24 #8
Check the one on the PTO lever. Doesn't take much!
/ Interlocks on BX24 #9
I second that. Sometimes my BX24 would start and other times it would be dead. There is a switch on the PTO lever that has an adjustment. Mine had slipped and was right at the edge. I moved it and haven't had any problems since. No pictures, but if you look at the PTO engagement lever it is pretty self explanatory.
Doug in SW IA
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
Landhonor Adjustable Rolling Creeper Stool (A66408)
Landhonor...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
Allmand Light Tower (A65579)
Allmand Light...
RC Mower TK-52XP (A65579)
RC Mower TK-52XP...
International 806 Wheatland Tractor (A66285)
International 806...
