My New J2023 Initial Review
   / My New J2023 Initial Review #21
I'd gently suggest a search elsewhere here on TBN.
I think others have stated that loaded rear tires are unable to lift any load off the front axle. Loaded tires can keep the tractor from wanting to tip forward when the loader is operating. A three point ballast box uses the rear tires as a pivot point and therefore the ballast box will lift load off the front axle.
Not debating, just trying to nail this down for the benefit of all. (I obviously was not a good student in certain science/physics classes.)
I'll be filling the tires regardless. The bucket won't hold enough weight to damage the front axle anyway. If so, my manual would be more specific about ballast weights. I can see this as a concern for tractors with much larger buckets though.
In the case of my specific tractor, I believe fluid in the rear tires well be more than sufficient and a rear ballast won't be necessary.
   / My New J2023 Initial Review #23
A decision that suites you.
Thanks for the help.
   / My New J2023 Initial Review #24
.Congratulations on the new tractor.
   / My New J2023 Initial Review #25
Loaded tires will help keep the back wheels on the ground which is a good thing. However to limit the weight on the front axle you need ballast behind the back axle.
   / My New J2023 Initial Review #26
Entirely your call, but any way you cut it, using the FEL without any/enough weight on the 3pt will definitely cause accelerated wear.
Put it in perspective....your FEL has 1,670lbs of breakout force, which is 100lbs more than the base tractor weighs! Having ALL of that weight leveraged on the front axle is a bad idea. Conversely, there is really no downside to having a bunch of weight on the 3pt.
If your tires spun on soft ground, it's not a ballast problem, it's a tire type problem. R4s spin very easily on soft ground....even weighted down with 1,400lbs on the back of my 4047. My Massey, with no weight out back, and unloaded tires, but R1s will walk right through the same areas.
I'll always have some type of implement on the 3pt regardless. I'm just not going to waste money on a ballast box and then have to hassle with unhooking what I have and the hooking up to a ballast box whenever I want to use the loader. My tractor won't be seeing a lot of hard use anyway.
   / My New J2023 Initial Review #28
Exactly what I said when I got my 2320.I am building ballast now because I've lifted the rear (with box blade) so many times. It's easy to add when you need it.
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2015 Hoist P360 36,000lb Diesel Forklift (A55973)
2015 Hoist P360...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
2012 Freightliner Bucket Truck (A55973)
2012 Freightliner...
2004 FORD F-650 SUPER DUTY CAB AND CHASSIS (A58214)
2004 FORD F-650...
