Extended idling vs switching on and off
   / Extended idling vs switching on and off #51
On many small tractors, including my B7610, the number only reflect the hours as if the tractor was run at PTO speed. [/URL].Thus, the number is essentially meaningless for the unaware buyer.
This is true on speed/hour meters driven by a cable such as your B7610 but not true on electronically controlled speed/hour meters such as my M7040
   / Extended idling vs switching on and off #52
I'm confused here.:confused:
Your saying a cable run rpm/timer will not advance it's time unless you
run the tractor at 2400rpm's or the 540 pto mark?
   / Extended idling vs switching on and off #53
I'm confused here.:confused: Your saying a cable run rpm/timer will not advance it's time unless you run the tractor at 2400rpm's or the 540 pto mark?
@ 2400 RPM 1 hour of running time puts 1 hour on the meter.
***The following numbers are made up and serve as an example only.***
@ 1200 RPM 1 hour of running time puts .5 hour on the meter.
@ 600 RPM 1 hour of running time puts .25 hour on the meter.
   / Extended idling vs switching on and off #54
I actually arrange my day such that I get my on seat work done, then shut down and do the off seat work. I rarely ever run a tractor for less than an hour.
   / Extended idling vs switching on and off #55
Ok, thanks for that, something I never knew.
I'll have to check that out on mine.:thumbsup:
   / Extended idling vs switching on and off #56
When buying older tractors with the cable style, it is good to keep this in mind, particularly if comparing to a straight 1=1 hour meter.
When selling an older tractor, the lower hours showing on a cable style meter could be an advantage depending on the understanding the buyer has.
Having said that, proper maintenance is as much, or more important than hours.
   / Extended idling vs switching on and off #57
I know a fellow that is a heavy equipment operator/owner/mechanic and contractor that has all kinds of trucks,tractors bull-dozers ect. and I know he never runs his equiptment at more than idle at any time and has run this way for fifty years.He is known as "IDLE JIM".
   / Extended idling vs switching on and off #58
And I bet his older equipment shows low hours. He must not have HSTs.
   / Extended idling vs switching on and off #59
Idling is seldom productive. We owned a small fleet of OTR trucks. We installed APU for driver comfort and to stop nightly idle. Our Freightliners were set to kill engine if brakes were set after just a few minutes of idling. Our trucks were sold when they resched 900000 to a million miles and never replaced a started. So I dont idle any motor for more than a minute or two. It is easier to get a preium price for a low hour tractor when you trade wheater its one year old or twenty.
   / Extended idling vs switching on and off #60
And that's the best way to do it...plan your work.
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
Nissan Forklift (A55973)
Nissan Forklift...
MACK GR64F DUMP TRUCK (A59823)
MACK GR64F DUMP...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
500BBL WHEELED...
