Grapple Failure
   / Grapple Failure #1
bhh
Ulster County, NY
Kubota L3800
Well it's happened. About 1 year old with only 25 hours of use. I've been easy on it so I'm not really sure how it happened although I suspect the opening pressure of the cylinder had something to do with it. These forums is where I found out about this particular grapple but the "value" vanishes pretty quickly after something like this. The warranty is only 6 months but I contacted them anyway to see if they would offer a replacement at cost or other gesture to indicate they stand behind their product. The woman on the phone ask me to send photos and said someone would give me a call back but that was several days ago and no one has responded yet. I knew not to get my hopes up however when the woman said something along the lines of that is their cheapest grapple and you get what you pay for. Anyone have any ideas about exactly what happend or if this is repairable.
EDIT: I'm not sure if it is appropriate to mention the company here or not. Are there forum rules regarding that? I don't want to be seen as ripping on the company but think people should be able to make informed decisions about products and the companies that sell them.
EDIT 2: Since I am getting PMs anyway, I might as well go ahead and note that this grapple is from Wildkat Attachments.
   / Grapple Failure #2
I think you had better go into more details regarding the problem. I do not see any component failure in the pictures you submitted.
   / Grapple Failure #3
The tower (for lack of a better word) where the cylinder mounts is shoved backwards from what I see. Looks like the mounting point is not strong enough.
   / Grapple Failure
This weld has failed where the bracket that hold the cylinder is attached to the top cross bar. The result is the grapple will not close all the way (about 12" open in closed position). The bulge in the crossbar indicates to me that there has been considerable pressure on it. I think if the cylinder was not installed and adjusted properly, opening grapple jaws all the way could have forced the cylinder bracket down through the crossbar. Its a little hard to describe.
   / Grapple Failure #5
Well, It sure looks like an easy fix!
Problem is the post won't take the pressure when you are clamping down on a load.
Pushing the tower back, or actually rotating the tower relative to the beam it's on. That's how the weld failed "inward", shearing the HAZ next to the weld fillet.
The fix?
Chain the grapple jaws together and use the hydraulics to try to OPEN the jaws. This will pull the tower back into it's useful position. Go slow, Look all around to make sure you are not tweaking something else!
Then when in position, vee out and weld the crack.
Then, BOX in that tower! I would plate down and across the transverse beam (the one the tower is on) on both the back and front of the tower. Triangular plates out to the full width of the present gussets and about 3 inches more. the plates should go to the lower edge of the beam, and up to the cylinder end mount. End up with a sandwiched tower and plates that are now in compression and tension and not a weld in bending..
$50 in 3/8 plate and a couple pounds of filler rod should do it!
Best to set the grapple off the loader arms so you can get access to the weld areas.
   / Grapple Failure #6
Yes, it appears to be an easy fix but wouldn't you think that something like that should be strong enough to take the entire force of the cylinder closing the grapple? In my mind, whoever built this unit should consider that regardless if it is the least expensive model.
"you get what you pay for"? I could say that about something I buy if I try to cut corners but to have the manufacturer say that. Come on.
As far as the repair, after it's fixed the cylinder could be replaced with a smaller diameter cylinder. That would reduce the muscle the cylinder has when closing the grapple.
PS edit...
as far as naming the manufacture goes, I know that I wouldn't want to buy one of these and experience the same failure. A private message to me and anyone else who asked naming the manufacturer and the model number would be an OK deal. Might save me some grief down the road.
   / Grapple Failure
The fix?
Thanks Calg, that sounds like it could work. I couldn't figure out how to "unbend" it but chaining the jaws together will probably do it. I don't weld but I've got a neighbor that is pretty handy with a welder whom I'm sure I could trade a little seat time with to do this. How long do you think something like this would take? Thanks so much for the advise.
   / Grapple Failure #8
Also, and I guess I'm on a roll here, :D why should you have to "be easy" on a tool that you buy to work. I'm not talking about abusing the thing but you shouldn't have to baby it.
   / Grapple Failure
I agree, when I say take it easy, I mean bashing the thing into trees or what not. I also agree with your thoughts about the manufacturer. I was terribly turned off by the response. Its not like I am running it on skid steer or a 60HP tractor or something.
   / Grapple Failure #10
The fix?
This sounds like it would work to me. And is how I would attack it also. yes the top square tubing is too light, we have heard of this before, but it can be "worked around" and repaired for not a whole lot of money, just some time. I think this is well within the grasp of a hobby welder like me, but if you cannot weld, or don't feel confident, at least get the tower pulled back out of the top tube using the hydraulics like CalG suggested and then take it in to a local welder and they can fix you up. The original welds don't look all that good to begin with, but the tubing is just too light duty, and that is the root cause.
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2006 Pearson Quantum Fire Truck (A50323)
2006 Pearson...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2020 EZGO GOLF CART (A50324)
2020 EZGO GOLF...
