John Deere 1020 PTO (clutch) problems.....
/ John Deere 1020 PTO (clutch) problems..... #1
historyan1975
Transylvania, Romania
JD 1020
Hi...
I have a JD 1020 tractor .... When I try to shift on the PTO, not responding.... I tryed with the depressed clutch pedal - nothing, with undepressed clutch---- nothing...:confused:
Please, help me.... If you want, I tryied to sending video .... Sorry for the my poor english...........
Sincerelly,
Benedek J.
/ John Deere 1020 PTO (clutch) problems..... #2
Alternative operation for a tractor with a stuck dual stage pto clutch other than R&R of said clutch is engage pto lever before starting engine then after pto is engaged start engine. This feat is to be performed with EXTREME CARE.
Thanks for the fast answer, Tx Jim...
I also do in the same way for two years - I engage the PTO lever and after that I start engine.. But, if I do in this way that is not useful for the tractor's starter motor..
My question is that originaly - how is working the PTO, how do we need to start in order not to cause damage.
Ex. I start the engine, than do I have to press cluch pedal.... or I just have to switch ON the PTO lever? At the moment it is no difference between I press or I don't... The PTO lever is not moving and not switching.... Only very hard and its making strange noises... Finaly ----- I not making things in right order or maybe the PTO has problem????
I suppose other modell have the same PTO/system...????
Bye....
/ John Deere 1020 PTO (clutch) problems..... #4
If pto clutch is stuck(as I think it is) the only GOOD SOLUTION is to split tractor & R&R clutch components.
/ John Deere 1020 PTO (clutch) problems..... #5
independent pto.gifDo you have a lever like this between the transmission shift levers? If so, then pushing in the clutch has no effect on pto. Push down on this lever to disengage pto clutch. The lever on the left side of transmission beside your left foot disengages the splines on the shaft. The lever between shifters is a hydraulic clutch for pto. If you do not have lever between shifters, then the foot clutch should stop pto and tractor needs to be split to repair.
/ John Deere 1020 PTO (clutch) problems..... #6
jd110
I asked that same question of historyan1975 on a different thread and they stated no lever between gearshift levers.
No lever... only PTO ON/OFF switch lever on the tractor'"s gearbox left side...............
If you watch the following video as I also did you will see that the tractor JD 1020 made in 1966 has PTO/engage lever.... But my tractor made in 1975 does not have PTO lever between shifters...
Then the final conclusion is that the foot clutch should stop pto... which in my case is not working in this way...
P.S. Does somebody have a JD 1020 tractor transmission or gearbox/scheme???
http://www.youtube.com/watch?v=-GNOqcl8C6A
/ John Deere 1020 PTO (clutch) problems..... #8
Have you considered purchasing a JD 1020 tech manual??? Technical Manual TM4286 1020, 1120 & 1630 Tractor Here's one on Ebay.
Tx Jim.... The JD 1020 PTO problem is unraveled.....................
/ John Deere 1020 PTO (clutch) problems..... #10
And as Paul Harvey stated "what's the rest of the story?"
Simple... The clutch pedal had to be pressed - with force... DUAL STAGE CLUTCH..no?! And the PTO clutch now is working normaly....
/ John Deere 1020 PTO (clutch) problems..... #12
I'm glad it was that simple.
Accu-Line 110V Tire Changer (A64556)
Accu-Line 110V...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
MACDON FD75S FLEX DRAPER (A64278)
MACDON FD75S FLEX...
Unused John Deere Service Advisor V3 Electronic Data Link (A64194)
Unused John Deere...
Tropic Trailer (A64557)
Tropic Trailer...
2016 Kia Sorento SUV (A64557)
2016 Kia Sorento...
