Loader leveling rod
/ leveling rod
azranger, was your setup correct when you purchased or has it always been off? Guide rod too short, guess you could cut the sleeve a bit to compensate, too long, just paint a ring on the guide rod to indicate level.
mangus, sounds interesting. will be waiting to see the completed project.
No it was off from day one. It actually could be about 1 1/2 longer. I read somewhere"dont know where now" that there was a short rod and a long rod. I may just add to it with some 1/2 round stock.
/ leveling rod #22
What did your dealer say? Maybe the wrong rod was installed, and they could get you the right one?
/ leveling rod #23
I don't know how flat your land is, but I'm on a bunch of hills. I find that level is never quite right no matter what you do. I find the Leveling Rod is good to get me close, but if I'm doing anything that requires a fine adjustment, then I have to do it by sight.
/ leveling rod #24
I think if I were going to add rod, I would add a lot more and then cut a groove/paint bright color at level. This would show level and still have some rod sticking out so that you would have an indication of how much tilt you have past level. Cut off the rod at some point in dump cycle at which you no longer care how much tilt you have.
This would be good to know how much tilt you have past level rather than bringing it all the way till you see the rod come out, then lower it back a bit for digging. You could customize the rod to show best angle for digging by adding another groove.
/ leveling rod #25
I test drove a J2030 today and I noticed the same thing. The level rod was about an inch longer than the end of the sleeve when the bucket was level.
/ leveling rod
I spoke to dealer this morning, he said he would swap it out with one he had on the lot, it will be next week before i can get down there.
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
Caterpillar 65-95E Tractor Service Manual (A63117)
Caterpillar 65-95E...
2007 FREIGHTLINER CL112 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2007 FREIGHTLINER...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
