Front Snow Blade
/ Front Snow Blade #1
E3A
CT
Kubota B2620
I rec'd some (wise) advice to look into the LS Tractors so I've been looking at the J2023. Looking at the Mahindra and the Kubota, I see that they both have a front snow blade available but I don't see one mentioned anywhere for LS on their site and nothing came up on Google. If I went with LS and wanted a front snow blade, am I out of luck?
/ Front Snow Blade #2
No you are not out of luck, you can use any blade with a quick attach. (Sized for your tractor of course!)
Something like this: HLA Snow
/ Front Snow Blade
Something like that mounts up to the FEL, correct? The others I saw from Mahindra, Kubota, Deere, etc. all seemed to mount below the machine without the FEL attached. Is one style better than the other?
/ Front Snow Blade #4
It's the typical decisions between after market/open market equipment vs. manufacture specific equipment. The manufacture equipment is probably a little better, as it is designed to work specifically with the make/model, but if you ever get rid of the tractor for another brand, or if you go up to a bigger size, then it may not work and you have to get a new one. After market will fit on multiple tractors if you upgrade or a different brand. Also if you don't need the piece anymore, it's easier to sell.
Personally, i would not let brand specific equipment play into your decisions. Unless, it's a package. I can get the tractor and the piece of equipment for the same price as the other tractor as the special this month.
/ Front Snow Blade #5
I think that plows mounted directly to the tractor frame ( not on the FEL) offer better
directional control, as it is not as far out in front, especially when the plow is angled.
Also, you might want to check out warranty issues on the tractor. When I was looking
at the Bobcat CT235, they didn't offer a FEL mounted snow blade for that model, just
a frame mounted plow. A further check found that the CT235 warranty stated that
the use of a FEL mounted snow blade would void the warranty. That's why I went
with the CT335, which has a heavier frame and FEL structure to take the additional
stress from a FEL mounted snow blade.
/ Front Snow Blade
Good to know - thank you.
/ Front Snow Blade #7
E3A. I've been researching subframe mounted front blades for a few days now. I have a BMX184H front blade and subframe. The MF 1550 and the Kubota L2184 are the same blades, with hose length and couplers maybe different. I found this information from the company that makes these blades and subframes. For me the thing to consider is the cost difference of a front loader and bucket vs front blade and subframe. I asked a local LS dealer about their front subframe mount snowblower and have not heard back. lt190b
/ Front Snow Blade #8
really, their warranty expressly forbids front mounted plows....that sucks.
I called Kioti on mine, and they have no issues with them. i didnt think any tractor cared what implements you used.
then again...ive been told that unless you buy full sized TRUCKS WITH factory plow packages...any use of a plow voids warranty. i think dealers want to do anything to void warranties.
/ Front Snow Blade #9
It wasn't the dealer! He was going to sell me a 72" snow blade with the CT235, and wasn't
aware of the warranty clause, and didn't know why Bobcat didn't offer the FEL mounted
snow blade on their website when pricing out the CT235. I called the Bobcat headquarters
in North Dakota
/ Front Snow Blade #10
in North Dakota
i called the Kioti rep on my questions...cause i dont always fully trust the dealer for answers that will hold up in a warranty issue. i also asked about
1. front plow - no issues doing so
2. Block heater installed in freeze plug - they said they understand why i would want it, but they said not to do it. So i didnt
3. Chains on front tires - they had no issues with that
/ Front Snow Blade #11
Personally, I wouldn't want to have to bother with taking the FEL off to put the front blade on. I don't see how carefully plowing with a trip-edge blade would be any worse than what we often do with the bucket. The big thing would be to keep the speed down, and learn the area you're plowing to find those spots that will catch the blade and put stress on the FEL. Once you have that sorted out, pushing snow, by itself, isn't going to hurt the machine.
/ Front Snow Blade #12
yup. your right
when i plow snow i cant get going too fast anyways, generally running in mid range with the HST. Ive sprung the trip 2 times in past 3 snow seasons. no big thing
/ Front Snow Blade
My need is based more on tightening up the turning radius to meet a need on my property - but I may be able to get around that need with some creative back blading.
/ Front Snow Blade #14
not sure how much the plows you all are looking at cost but i know for me in my location it is a way cheaper route to find and old truck plow blade and make some minor mods to it and mount that on the front of the FEL in place of the bucket.
not sure why the pic is so small but if you follow the link below the image is much much larger and could be used to easily duplicate.
Alaska Tractor Offerings
this is not my ad of course, its one my dealer posted although the tractor on the left with the blower attachment is mine now as well as the fork/grapple attachment.
/ Front Snow Blade #15
Nice rig!
/ Front Snow Blade
That must move some snow!
/ Front Snow Blade #17
E3A. I never did hear from the LS dealer about the front blade, but I did visit with the guy from RADTEC, he says they make the snowblower and subframe for LS and yes the 84" blades from case,massey and kubota will fit. Only diference might be hose length an couplers. lt190b
/ Front Snow Blade #18
Here's my front mount on my J2023H.. works fine except that the blower needs taller skids on my gravel drive.
/ Front Snow Blade #20
It's a 70 GMC short box step side- just finished it 6 months ago- my first attempt at restoration... earned a lot about what not to do... thanks for asking. Phil
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61572)
2025 BrushFox...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2007 International 8600 Parts Truck (A63689)
2007 International...
2006 Volvo VNM S/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM S/A...
2009 Blue Bird All American/ All Canadian School Bus (A61573)
2009 Blue Bird All...
