The Jerry Can Conundrum
/ The Jerry Can Conundrum #1
oercheron
Aldergrove, BC
2 Kioti, 2 John Deere. None wore out yet but the '49 ain't used that much anymore
Things that make it hard to get up in the morning:
-Knowing that all 8 Jerry cans full of fuel are at the FRONT of the pickup box and INSIDE the canopy. Ahead of a full pallet of sacked cement with grease guns, chainsaws, and several shovels & rakes on each side. And a fully-loaded trailer that won't let you lower the tailgate because the jack is in the way.
-Having to fill a machine that takes 2 or more Jerry cans to fill
-Having to fill a machine that takes slightly LESS than 1 Jerry can to fill
-Having to unload 8 Jerry cans from the pickup and carry them to a spot you can't back up to
-Not having enough Yellow cans for the diesel and/or Red cans for the gas
-Also having mixed gas in one of the red or yellow cans. But not labeled.
-"Green" jerry cans
Here is how I fixed part of the problem for hardly any $ - Diesel transfer tank - YouTube
/ The Jerry Can Conundrum #2
I'm sure that meet all applicable codes (tongue in cheek) :) But it works and that's what counts.
/ The Jerry Can Conundrum #3
Skid tank in Ontario must be bolted to the bed they are carried on (bolted to the trailer/pickup bed). The goobermint changed the ruling 2 years ago. :(
Still OK in BC for this size container. Ratchet straps will meet requirements.
/ The Jerry Can Conundrum #5
When I got tired of screwing around with Jerry cans I started using an electric fuel pump. Have a hose that goes in the can, and a hose that goes to whatever is getting fueled. Plug it in and it starts pumping. Far easier and a little bit faster than if I did it manually.
/ The Jerry Can Conundrum #6
That's what I am currently doing, hoping to build a fuel trailer soon though. The little HF diesel pump empties a 5 gallon in short order! It's certainly a billion times better than holding up the cans though.
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
PALLET OF TOOLS (A67714)
PALLET OF TOOLS...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
2014 INTERNATIONAL 7600 6x4 T/A DUMP TRUCK (A66091)
2014 INTERNATIONAL...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
