tubing for front end loader
/ tubing for front end loader #1
jholland
cub cadet 86,cub cadet 109,ccc/mtd 580
I'm in the process of building a front end loader for my cub cadet. Got the plans from P.F. Engineering. Their plans call for hoses all down the boom for the cylinders, but I would like to use a tubing along the boom and branch off with the hoses for the cylinders. Does anyone know what type tubing I should use and a good place to purchase it. Thankful for any info. Jeff.
/ tubing for front end loader #2
Most hydraulic supply houses carry it...if you don't want to paint it you'll need stainless...
I'm in Stanley, North Carolina. Another question, my hydraulic hoses are 3/8 npt with an inside dia of 0.274. Should my tubing have basically the same inside dia? And should the outside dia be the same as my hoses. And also what about wall thickness. Just want to be sure and get the right stuff. Thanks, Jeff.
/ tubing for front end loader #5
I'm in Stanley, North Carolina. Another question, my hydraulic hoses are 3/8 npt with an inside dia of 0.274. Should my tubing have basically the same inside dia? Yes. And should the outside dia be the same as my hoses. No. And also what about wall thickness. Just want to be sure and get the right stuff. Any hydraulic shop will have the right stuff. Thanks, Jeff.
I am guessing that you don't have the special tools to bend and flare hydraulic tubing and crimp connectors to hoses.
My loader came with the tubing, so when I finished the put-together, I took it to a hydraulic shop and they made the hoses that hook to the tubing.
I recommend that you make some type of quick connect system for the attachments. Look at my thread and you will see why I wish that I had done it before I made my pin on attachments. http://www.tractorbynet.com/forums/customization/272163-fel-toro-groundsmaster-put-together.html
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
213087 (A64276)
213087 (A64276)
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
case 370 glass door never installed (A61307)
case 370 glass...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
