Well question
/ Well question #21
If your schrader valve is screwed into the well side of a brass check valve in the supply line, you have an air making system. Which also means you do not have a bladder tank. This system works great when it's functioning. If the schrader or the bleeder in the well gets plugged; the tank will waterlog causing the pump to cycle rapidly. Make sure the pictures show the entire tank and also the schrader valve.
/ Well question
The Shrader valve is below the pressure switch.
/ Well question #23
I am going to have to bow out of this ,that setup is nothing that I have ever seen !!!!
Best of luck, hopefully someone will step in that knows your system.
/ Well question #24
I have this setup on my home. It is likely your air volume control.
Air Volume Controls are designed for domestic water supply systems which deliver a quantity of air to the pressure tank with each cycle of pump operation.
Insufficient air in the pressure tank causes frequent operation of the pump.
Too much air in the pressure tank will permit large bubbles to be carried into the piping system. This causes a disagreeable noise and sputtering at the faucets. It is the function of U.S. Gauge air volume controls to maintain the correct relationship between the volume of air and the quantity of water in the pressure tank.
Air volume control: How to Find & Repair, Replace, or Remove the Water Tank Air Volume Control
/ Well question #25
Ok, that's no bladder tank. (I'd look into getting one.) Your Schraeder valve is 'randomly' placed in a well fitting (1" w/ 1/4" taps). It'd be ok for adding air and that's about it with no way to monitor the amount/level if no other apertures are available.
These kinda faded out in use decades ago as bladder tanks came into popularity. Galvanized tanks are so '70s nowadays, and that they last so long has little to do with how well they work. Got VISA?
/ Well question #26
I have both kinds of tanks and will probably add a new galvanized one on the well I just drilled. I prefer it over bladder because it allows you to add air as the OP indicated to reduce suffer smell plus about the only thing that can go wrong is the AVC which is cheaper to replace than bladder. The one at my house has been workin since '97. Not quite the '70s but 17 yrs.
/ Well question #27
My fiberglass bladder tank is 23 years old and operating trouble free.
Steel bladder tanks are another story, the steel inner side of those rust from condensation and the bladder abrades on the rusty surfaces and eventually pop a few leaks.
Another MUST is to ONLY use brass or plastic fittings as any steel in the system will rust to the point of impeding flow and even cause total blockage. Also depending on the water pH, some areas will eat up piping real fast.
/ Well question #28
Pretty much a race between rust and air loss to finish off a bladder. Condensation comes from any damp air we put in above the bladder when setting up or topping up (that can be a warning sign) if anyone wonders. Now there is a place for the magical 'nitrogen' ;)
While no longer as popular, galvanized tanks are as nice to have as they are 'er easy to check/correct air volume. I can relate, cuz' I prefer a motorbike with a kick starter and point ignition. :thumbsup: (same would apply to scheduled bladder air checks, btw) What matters more to some is water quality, to the point that gases etc can be heqq on bladders if minerals or ph doesn't cause zinc to react somehow. Don't let plastic sections or fittings defeat any grounding if not deliberately isolated. :2cents:
/ Well question
C4Ranch Thanks, the part under the gage looks like the link you supplied. I will pick one up and replace it.
Thanks everyone.
/ Well question #30
I looked briefly at the link that C4Ranch posted. If I looked at the same picture of the "part under the gage" as you, that part is a float valve that removes excess air from the tank, and is not likely your problem. The most likely source of your problem is the "snifter valve", the Schrader valve. They get clogged with minerals and fail to open which causes them not to allow air into the line to replenish air in the tank.
In short, the snifter valve, working with the ball/tee in the line in the well works to add air to the tank each time the pump turns on. The float/ball valve about halfway up the tank removes any excess air that has been injected.
You can restore (temporarily) correct operation of the system by using an air compressor on the snifter valve to add air to the tank.
/ Well question #32
I do this for a living and have been for over 45 years. You have a galvanized tank with an air making system. Either your schrader valve is plugged up or your bleeder which is in your well in the drop pipe is plugged. The air control you have lets air out. It doesn't put air in. The first thing to try is replacing the schrader valve or cleaning the old one so it can allow air into the pipe once the pump shuts off. Once you clean or replace it, put a drop of water on top of the schrader valve and cycle the pump. When it shuts off, the drop of water should disappear as the schrader draws air. If it doesn't you will either have to pull the drop pipe up and clean the bleeder or change to a good bladder tank. Never put a cap on the schrader unless you are going to a bladder tank.
/ Well question
I am pretty sure the shrader valve has a cover on it. I had to take it off to get to the vale to make sure it would squirt water.
Do I need to empty the tankl to get ait back into the system?
/ Well question #34
Pulling the cap off may fix the problem. Did it squirt water? The schrader squirting water others were talking about is for bladder tanks. Try the water on the schrader test. It would be a very good idea to drain the tank as soon as possible. Cycling the motor like that is not a good thing.
/ Well question
Speedbump
It squirted water when I depressed the valve with a thumb nail, will it fill with air on its own or should I add air with the commpressor?
/ Well question #36
Speedbump
It should only squirt water if the pump is running. When the pump shuts off, it should allow air to enter the pipe going to the well. Adding air with a compressor is only temporary fix. Replace the Shrader (snifter) valve.
Draining the tank and restarting will also put air in the tank.
/ Well question #37
In that case, if your galvanized tank is waterlogged, your bleeder is plugged. There are rubber, brass and stainless bleeders. They look like this: bleeder.jpg
They are generally about 10 to 20' down from the top of the well. If it squirted water while the pump was running the schrader is fine. If it squirted water with the pump off the bleeder is definitely plugged.
Yes, add air as soon as possible.
/ Well question
When I got home I turned the power to the pump off and took the Shrader valve cap off, I could here a short his of air. Pushed the valve down with my thumb nail and hear air. Opened the outside hose bib and filled with air from compressor until it quit bubbling. Left the valve open and turned on the breaker. Instead of 20 seconds between the switch kicking on and off their is probably a more than a minute with the hose bib open. Switch is not sounding like it is hitting so hard when it engages. Water drop on the Shrader valve disappears when pump stops. water pressure at he kitchen sink is steady, does not surge like it was. I will keep an eye on it and see what happens. Thanks for everyone's help
/ Well question #39
Sounds like you have it figured out. And your not the first guy to put a cap on the schrader valve. With it off, the tank should air up even more than what it had with your compressor. Eventually you will hear air hissing out of the air release (air control) valve just before the pump kicks on.
/ Well question
Thank you, I really appreciate the assistance.
2002 WACKER RD25 ROLLER (A59906)
2002 WACKER RD25...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2021 Bobcat T770 (A60462)
2021 Bobcat T770...
2024 Linx 7'X12' UT357714T (A60463)
2024 Linx 7'X12'...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
