Ford 5000 lift issue
/ Ford 5000 lift issue #1
2006gmcdmax
Gold Member
Augusta, GA
Many but mostly ford diesels or ihc or jds
Lift arm will not lift I can pick up freely, pto does work! which valve could be acting up? thanks
/ Ford 5000 lift issue #2
Does it have fel.if not there is a relief valve on the cylinder block that will get stuck or a blown o-ring where the lift top sits down the best i remember it has been a while sense worked on one . If got fel there is a valve under the set (not all have them)that I have seen get moved by getting on and off tractor bumping it with there leg and moving the valve
I figured it out it was the bypass valve and the u loader valve was stuck
