Show What Tool You Made*
/ Show What Tool You Made* #162
Don't have to bend it - you can use 6 plates and weld all the corners.
/ Show What Tool You Made* #163
Can you set a long sheet of smooth metal roofing below? Push the pile out with a rake?
Yeah.... I have a rolled piece of metal I want to mount just below the cutters and it will follow the curve of the drum... It should discharge pretty good... I pull the chopped straw out with a fork now... I have to disengage the PTO so something serious doesn't happen... It''s just a PITA to keep having to turn the PTO off...
I like that straw chopper. :)
Thanks Maverick.... It's a bit different.... and it was fairly easy to build....
/ Show What Tool You Made* #164
Agreed, that's why I would suggest to push the pile out from the backside (where you are standing to load it). If the roofing is long the pile will just keep sliding down the roofing.
Wait….are you driving the tractor while running this thing?
/ Show What Tool You Made* #165
Wait?are you driving the tractor while running this thing?
I have chopped while standing on the platform, on the rear of the chopper.... Bride was driving down the beds of garlic... I had a rack to store wafers of straw while I was doing that... Worked pretty good.... then I raked out the straw when we were done with the chopping...
Now I use it stationary, sort of... pull up to the straw bale and chop it all up.... then move to the next bale... etc... then pitch into apple bins so it was easy to move and store for later......
Doing anything around that chopper drum, while it is motion, is something that doesn't appeal to me... I wouldn't be able to read my obituary......
/ Show What Tool You Made* #166
Don't want to see this thread fade away! I am sure there are lots of good ideas still out there. Will offer up a super-low-tech tool for something that comes up all the time - cutting of floppy sheet materials like plywood and particle board. See photos. Two long boards, whatever you have, two short boards, whatever you have, screwed together to make a parallelogram. It collapses together to be stored in a corner when you don't need it. Screws need to be driven about 1/2" down to be out of the way of the blade. Add a third short board, movable, to support wherever you are making the cut. No more binding etc. Works good on any sheet material, especially odd shapes. Takes about 2 minutes to make using scrap you were going to throw away anyway.
/ Show What Tool You Made* #167
Soo simple! Thanks for the idea! :) :thumbsup:
/ Show What Tool You Made* #168
View attachment 361938View attachment 361939
I like it!:thumbsup:
/ Show What Tool You Made* #169
Choker Chain Grab Hook. Push it under the fallen log/tree, hook on to the choker chain, and then pull the choker chain under. A lot easier than pushing the pin end of the choker chain under and then trying to find it to grab it with your finger tips and pull it thru.
/ Show What Tool You Made* #171
Where did you get that choker chain?
I buy the choker chains or just the hooks at a logging supply or chainsaw dealer ( not box store or hardware chain ). You can order them on line from BaileysOnLine.com or Labonville.com Two size hooks are made for 3/8" or 5/16" chain.
/ Show What Tool You Made* #172
Thanks Gordon I'm getting one.......... Lee Johnston
/ Show What Tool You Made* #173
I built this fixture with parallel linkage and two arm pivots to hold the router in a vertical position while swinging it over a fairly large area. It's used to rout binding ledges on guitar bodies in this case but could be used for other router applications that require keeping the router in a vertical plane. The gas strut provides counterbalance and has an adjustable stop. Used aluminum 1x2 and 1x1 by 1/8" wall square tubing. All pivots are zero clearance with steel against UHMW.
Similar arrangements are used in machine shops for holding an air motor for tapping holes as a secondary operation to CNC machines.
Edit: Router appears out of level in the photo due to lens distortion.
/ Show What Tool You Made* #174
Nice workmanship. Can you give a close up of the vertical swivel joints on the angled 1x2? And how did you make them, I've been puzzling on this for days and cant figger it out.
I think i have the same bosch router came in a countertop installers kit. Have used it for everything for years very light and smooth.
/ Show What Tool You Made* #175
This shows the attachment of the 3/4" round to the 1x2 rectangular. The 3/4" shaft has two tapped 1/4"NC-20 holes to accept the 1/4" button head capscrews which pull the shaft tight inside the hole thru the 1x2. The "joint" is between the 3/4" round and the UHMW mounting block with the angle cut UHMW acting as a thrust washer. Used a long 3/4" endmill to cut the hole down thru the 1x2 on a 45 degree angle.
The curved links are bolted solid to the left 3/4" shaft and the pivot is between the 3/4" shaft and the UHMW sandwiched between the 1/4" plates.
Thanks for the interest. I'm more than happy to answer any additional questions, dimensions etc.
/ Show What Tool You Made* #176
Thats great, would really help when working solo. I could have used that many times. Except I'd lose it out in the woods somewhere. Easy to make another one though.
/ Show What Tool You Made* #177
Interesting. The base is withstanding significant bending force where any give could damage an expensive and time consuming work product. Gonna have to get some of that white stuff and start learning properties and applications. Thx!
/ Show What Tool You Made* #178
The weight of the router, during use, is actually resting on the workpiece (guitar body in this case) which takes the strain of the mounting UHMW base. One of the bearings on the cutter arbor absorbs this vertical load and also establishes the depth of cut in the vertical direction. A second bearing (commonly referred to as a rub collar) establishes the horizontal depth of cut.
You are certainly correct in "seeing the load" on the base and I'm planning to add a larger piece of metal under the base with three adjusting screws to allow leveling the base to the fixture table. I'm also currently adding a third member between the two curved links to align and stiffen them to each other. No end to the fun and I'm learning as I go.
The UHMW is interesting material to machine and cuts well with sharp HSS tools. It is difficult to deburr and just laughs at sandpaper. I prefer using Delrin as it isn't quite so tough. Aluminum would actually be a better material for the base but didn't have any that size on hand.
I retired from wheat farming in Western Oklahoma in 2003 and sold my 4450 John Deere. Lots of dust collected on the radiator and A/C condenser fins and is difficult to blow it out. I took a Milton type air nozzle, removed the tip from the 1/8" pipe threads and added a 24" piece of 1/8" black pipe. I welded the end shut, then drilled a .125 inch hole near the end to blow out at a 90 degree angle. I could then stick the pipe extension in between the radiator and the condenser, blowing the dirt out of both of them without damaging the fins. It really worked good.
Click on photo to enlarge, then look on the left end to see the 1/8" hole.
/ Show What Tool You Made* #180
graydog...that's pretty slick. Lots of guys around here could use that idea. OK to pass along?
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2021 Bobcat UV34 4x4 Utility Cart (A61572)
2021 Bobcat UV34...
2019 Ford Transit 350 Police Transport Van (A61573)
2019 Ford Transit...
