Kubotafan
Gold Member
- Joined
- Jun 25, 2012
- Messages
- 310
- Location
- Nova Scotia, Canada
- Tractor
- G1800AWS, B3030HSDCC, L3540HSTCC, JD710A
I have a L3540 Cab tractor with the electric defrost in the rear and corner glass. The tractor is used for snowblowing, and often times the snow is blowing back on you so the heated glass is a must to keep the snow melted and keep it for fogging up inside. The problem is that the power switch has a built in timer, so about every ten minutes it shuts off automatically, and I don't notice it until it starts fogging up on the inside. I suspect a regular switch could be used that would keep it on until it was shut off. Any problem with doing this, and what amp rating would I need on the switch?
