L3540 HSDCC Rear Window Defrost
   / L3540 HSDCC Rear Window Defrost #11
3540 fog relay.pngI would assume the timer is built into the relay not the switch as with most Japanese designed automotive electrical systems from the 80s-90s. The relay part number is 3F740-75030. Chances are if you pull the roof off and trace the wiring from the defogger switch you will find the relay right near the switch itself. I can't find a picture of the relay but there are 4 wires going to it and chances are it can be replaced with a simple relay of the correct amperage that would stay on with the switch operation. If I had a picture of the connector I could recommend one that would work for you.
What about the heated mirrors?:snowflake:
Good luck, Fred
View attachment 362008I would assume the timer is built into the relay not the switch as with most Japanese designed automotive electrical systems from the 80s-90s. The relay part number is 3F740-75030. Chances are if you pull the roof off and trace the wiring from the defogger switch you will find the relay right near the switch itself. I can't find a picture of the relay but there are 4 wires going to it and chances are it can be replaced with a simple relay of the correct amperage that would stay on with the switch operation. If I had a picture of the connector I could recommend one that would work for you.
Good luck, Fred
I will have to check again with my service manager. Heated mirrors would be nice, but the defrost is more of a priority to me. I do quite a few driveways, and everyone doesn't have limbs trimmed up the way I would like. My mirrors are often knocked out of position by the low branches, so aren't always properly set.
Miller Bobcat 225G AC/DC Welder Generator Set (A49461)
Miller Bobcat 225G...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2022 Caterpillar 420 Extendahoe Loader Backhoe (A49461)
2022 Caterpillar...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
2015 F-550 Bucket Truck Gas Engine (A51039)
2015 F-550 Bucket...
