tractor shelter
/ tractor shelter #21
bmaverick said:
Yes, that would work, but the cost in our area for even a small Sea shipping container is $2K. I had thought about that myself for my need.
Think how much a yard barn of equal size is though. Makes a container look good lol. Plus still stronger, and fireproof. Just not as cosmetically appealing.
/ tractor shelter #22
I had looked at sea cans and found that they are $2,500.oo F.O.B. toronto and I would still have to move one to here. 175 miles north of Toronto. The cost of the can + the move would buy me 4 Shelter Logic shelters. That is the way I am going. I am going to get another big SUV one for my little suv and then the one the heep is in now can go as a place for the summer/winter toys.
/ tractor shelter
How big a shelter will I need for the L3200 with a loader? I'm just looking for something to get me through this winter.
/ tractor shelter #24
How well do those Shelter Logics handle snow load?
Looks like it would shed the snow pretty well.
That might just be a very good solutuion for me.
I'm sort of on the fence between the Shelter Logic & the seabox, myself.
How hot do those seaboxes get in the Summer sun?
/ tractor shelter #25
My shelter logic SUV garage that I keep the Kioti in sheds snow real good. A little puff of wind and the snow goes. If no wind, when I go out to start the tractor while it is warming up I use the handle end of my chute poker and swat the underside of the roof.....The snow leaves. No muss, no fuss. And no aggravation.
/ tractor shelter #26
It looks to be no bigger than my CK27 and that is in a SL SUV garage. Height of the cab/rops is the thing that you need to worry about for getting in the doorway.
/ tractor shelter #27
Before I built my shop and machine shed, I parked my old tractor in a shelter from Costco, which was similar to a Shelter Logic. Here on the coast, things have a way of blowing away, so I used 2 heavy ratchet straps to secure the tractor to the roof frame tubing. Worked great for a year or so. I reasoned that if it was that windy, probably the tractor would be inside it anyway...Dan.
/ tractor shelter #29
both of my tractors have always been sheltered under Gods canopy. yes it would have been nice to have a building to put them in, and in extreme cold below 0F I will park in the shop so I can get started easer, but normally do not have room for normal storage, and with implement connected most would not fit,
and both are 40 plus years old and from what I can tell the weather has not hurt them besides some faded paints,
/ tractor shelter #30
The main reason for mine to be in a shelter is for the tires. I am also a tad lazy and don't like cleaning the snow off.
/ tractor shelter #31
Costco shelter has been working for me, strong winds shake it around, but it has stayed put. The biggest worry is the snow build up. It needs to have the snow removed before it gets too heavy. I had one collapse with 12" of wet snow. If it is around where you live, easy enough to remove the snow when needed (I just bump the underside with broom, snow slides off). If it is remote and the snow builds up, it could be a problem.
/ tractor shelter #32
Here is another option I just stumbled across from my new Farmtek catalog. The fabric has a 15 year warranty and I believe is thicker than most of the garage in a box items I have seen. But it does not have end enclosures. They do have a host of other buildings also.
ClearSpan SolarGuard Freestanding Buildings - FarmTek
/ tractor shelter #33
/ tractor shelter #34
Anchor it as well as you can... it isn't fun when they blow over.
That is a 20X30X14. After that little disaster, I anchored it with 14 duckbills.
/ tractor shelter #35
This is the reason I put a floor in the one for my Heep and then anchored the shelter to the floor.
(2x8's on top of 4x4'swith 1/2" gap between the boards. It is now heavy enough that it aint going anywhere.
2011 Jeep Wrangler Unlimited 4x4 (MPV), VIN # 1J4BA3H1XBL528743 (A61165)
2011 Jeep Wrangler...
2022 C&W Gooseneck Trailer (A64047)
2022 C&W Gooseneck...
2016 Ford Fusion Sedan (A61569)
2016 Ford Fusion...
Pallet of Chain Slings (A61166)
Pallet of Chain...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59909)
2013 ISUZU NQR 4X2...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
