Trailer Mesh tailgate
/ Trailer Mesh tailgate #1
jel1988
Gold Member
Elliot Lake, ON
2012 Mahindra Max 22, John Deere D120
I have a utility trailer with a mesh style tailgate. The gate is constructed from 5 pieces of 1 1/2 * 1/8 angle running the 4' length of the gate with one at the top and bottom. I would like to use the trailer to transport my SCUT around town but I don't think the tailgate is up to the task. I would like some ideas on how to modify the gate to handle this load. I don't want to remove the gate as I use the trailer for a number of different tasks. I have access to a mig but I'm not to sure how much steel I need to use. I still have to lift the gate so I don't want it to weight more than it has to. Any suggestions would be helpful.
/ Trailer Mesh tailgate #2
Have mesh gate on my dual axle trailer that handles a 4500lb New Holland. Mesh is very heavy duty and the frame of gate is 2x2 square tubing. I put a Gorilla Lift system on this as it was very heavy. Gorilla Lift makes much more manageable.
/ Trailer Mesh tailgate #3
adding springs to the gate will make it easy yo lift
/ Trailer Mesh tailgate #4
I also have trailer with mesh tail gate and have had it for years and works great for four wheelers and lawn tractor.
Not really worried about the mesh as I am the angle iron folding! I load my other lawn tractor all the time just doesn't look like it will hold the SCUT
Max rated load is 2300lbs
/ Trailer Mesh tailgate #8
Cut a piece of 3/4" plywood to bridge over the gate.
It will help distribute the load over a larger portion of the gate.
I don't know how this would affect the trailer towing the trailer will see the highway with the lawn tractor
/ Trailer Mesh tailgate #10
I also have a mesh gate. I used 1/4" thick bar laminated on the original thin wall tube. I put the new bars under the tire path. I welded them to the gate frame at the ends and stitch welded them to the original undersized members. I also added a Gorilla lift because of the weight.
/ Trailer Mesh tailgate #11
My mesh gate handled my Kubota B2920 just fine, so if you have a Max 22 as noted in your signature, I wouldn't worry about that at all.
You didn't say the width of your trailer so we don't know the spacing of the angles. On my gate, square tubes are used, spaced every 12" across the 7 foot width of the trailer/gate. The tubing is thin wall, probably 1/16" thickness.
What is a Gorilla lift?
/ Trailer Mesh tailgate #14
I'd say about 600 lbs, if he's a big ugly one. :laughing:
If I remember correctly, there are 2 cables that hook to your tailgate and are hooked to springs (or pistons ?) enclosed in a housing that sets on each side rail of your trailer.
They are really nice and saves your back from having to lift a heavy tailgate. You still have to assist it along but it handles the major portion of the weight.
/ Trailer Mesh tailgate #15
Lift assist using springs & cables for the ramp-gate. I made my own with garage door springs in exhaust tubing:
My 16' trailer also has two heavy coil springs on the hinge pins:
This gate was built to hold up a 7500# tractor! ~~ Lowell
/ Trailer Mesh tailgate #16
Looks good! :thumbsup:
I need to do that to mine. For some reason my tailgate is getting heavier all the time. I'm sure it's not because I'm getting old, though. :laughing:
Btw, in this pic I see you saddled a dead horse, although I don't think you'll have any problem with the cable slipping. :laughing:
http://www.tractorbynet.com/forums/...2521095-trailer-mesh-tailgate-picture-011.jpg
/ Trailer Mesh tailgate #17
A pair of ramps over the tailgate might make sense if you had other uses for them.
/ Trailer Mesh tailgate #18
Anyone that builds a gate should make it so it will lay flat on the deck when pulling it unloaded. Even mesh creates a ton of drag.
I'm another satisfied gorilla lift owner.
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
30in. Mini Excavator Bucket Attachment (A61572)
30in. Mini...
Bobcat MT85 (A60462)
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59912)
2016 GENERAC...
