Most, if not all of the new JD machines use Low vis hy-gard or regular hy-gard in the front axles. The 3x20's and the 4x20's definately call for it. I put regular hy-gard in my axle. I've pondered on it quite a bit, talked to my dealer about it, and even started a thread here on why not gear oil. The answer the dealer gave me was that gear oil would be OK, if you got the other oil flushed out good. But, he said that the rear final drives are running in hydraulic oil, so if its good enough for the rear drives, it's good enough for the front axle. I would think that gear oil would be less likely to leak, and that's why I went with regular instead of low vis hy-gard.
I think rear ballast is pretty important to front axle health also, I run 1000 pounds of steel on my 3 point.
