3PH pin marring
/ 3PH pin marring #1
UTCenturion
Member
Tennessee
Kubota M5140 4x4 tractor, Bobcat 331G excavator, BCS 749 walk behind
Whats Causing this and how do I prevent it. I went to remove my rotary cutter and the pin sleeve got stuck at a certain point on the pin. After hammering with a dowel I got the pin out but its covered in surprisingly deep grooves in the middle of the pin area. What am I doing to cause this and how do I prevent it?
/ 3PH pin marring #2
It's the low quality of the metal in the pins . And no grease .
Sent from my iPhone 5 using TractorByNet
/ 3PH pin marring
I actually had grease on them at the time. I cleaned the grease off to be able to better take photo of the damage.
/ 3PH pin marring #4
Just the low quality of the metal I have noticed the same thing on the new pins I have bought over the older ones I have had for years .
/ 3PH pin marring
Yuck, I've swapped for a spare pin I had handy, can I sand the high bumps off and reuse this pin or is that asking for trouble.
/ 3PH pin marring #6
I suspect you'd lose too much structural strength sanding the gouges out completely.
That also doesn't address the gouges in the female/receiver side of the pin connectors. You may need to replace the whole connection assembly.
/ 3PH pin marring
I'll check the connections on the 3 point hitch for marks. I have had the rotary cutter attached with a new pin for a few days with no visible effects. I was just thinking of keeping this pin as a spare, but sounds like I just need to throw it in the scrap heap.
/ 3PH pin marring #8
That pin looks long so I assume it's the top link pin?
Sometimes the fit-up on the implement top links are kind of a sloppy fit. I've seen top link brackets on some implements being wider than necessary, allowing the components to work back and forth. If that's the case, then I can see where dirt/sand/grit could get on the pin and the grease holding the grit in place would wear the parts. Without a pic of the whole assembly together, it's hard to tell for sure.
Regardless, though, I would still think that the pin is softer than it should be.
/ 3PH pin marring
its actually a lower pin for the left hand side facing the tractor from the rear.
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
