Brush Forks for 23HP Kubota BX2350
/ Brush Forks for 23HP Kubota BX2350 #23
Here is a quick video picking up and moving trees while burning:
Kubota BX2350 Brush Forks - YouTube
I hope your tractor is insured! And you are not wearing a seat belt, so you can get off quick when it catches on fire.:eek:
This is what I use after the fire is out.
Nice tongs Xfax!
I rebuilt my forks over the last several days. I used square tubing to build the entire frame and thick flat-strap for the "hangers". I still have to rebuild the bracket on one side, it got bent up pretty bad. These still install and remove very easily as long as the ground is level. They are still light enough to pic up if neccessary, but noticably heavier than the prototype! Here are the pics:
/ Brush Forks for 23HP Kubota BX2350 #25
Nice tongs Xfax! Thanks
I rebuilt my forks over the last several days. I used square tubing to build the entire frame and thick flat-strap for the "hangers". I still have to rebuild the bracket on one side, it got bent up pretty bad. These still install and remove very easily as long as the ground is level. They are still light enough to pic up if neccessary, but noticably heavier than the prototype! ---------
Looks gooder-un :thumbsup:
/ Brush Forks for 23HP Kubota BX2350 #26
I am going to be building some brush forks soon. I have looked at several designs and will use a little from several designs. I like your bolt on design. I have also been toying with the idea of building one onto a skid steer quick attach plate.
I highly recommend them. I need to make a video of how to install and remove the forks... need more time in the day for stuff like that!!
I like having the bucket still on the tractor with the forks. I can push brush and still load the bucket with firewood if needed, etc. However, I don't have a quick attach so that's not an option for me anyways!
These have come in handy cleaning up around our new house!
/ Brush Forks for 23HP Kubota BX2350 #29
I've been real happy with quick attach for my brush fork . Yours is almost quick-release I bet you could use a pin and spring clip instead of the bolt.
My BX moved MOUNTAINS of brush, and so maneuverable, was easy to get stuff to the fire. I like your movies!
I like your idea! I'm picturing something like the pin and spring that holds the mowing deck on my BX... that might be a project this winter!
2023 FREIGHTLINER M2 4X2 24FT SLEEPER BOX TRUCK (A59906)
2023 FREIGHTLINER...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
John Deere 5075E (A60462)
John Deere 5075E...
SANY SY225C9C5KL EXCAVATOR (A59823)
SANY SY225C9C5KL...
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
