Learned Something New About Loader
/ Learned Something New About Loader #1
rwork
Mississippi Gulf Coast
Kubota B6100 LS R3039H
I didn't even know this was possible until someone posted about their loader not being able to curl / dump while in the float position. I thought about this yesterday while I was grading my drive, and gave it a try. It works! I've had the tractor almost two years, and never knew!
Any other secret tricks??
/ Learned Something New About Loader #2
? I am missing something maybe. You should be able to curl/dump while floating the lift arms. It is a fantastic feature smoothing and grading. Are you saying that yours doesn't?
No, mine does. Just never knew that was possible. Someone posted a little while back, that their tractor was able to do it, but no longer could. I had never even heard of that before.
/ Learned Something New About Loader #4
Oh. Good. Best way to smooth surfaces is back drag with the bucket almost level with a slight tilt up or dump down and used the front edge. Trick is slight adjustments as you finish off not to dig to deep or leave a pile at the end of the drag.
Learn something new every day !
/ Learned Something New About Loader #6
I sure wish I could grade my drive, it's not bumpy, just full of this #$^&## snow again. Can't wait to see the ground again. 23 in. of the white crap on the ground, deeper where there is drifting. One trick I learned not to do is drag backwards with the bucket in the full dump position and the front tires off the ground. I bent both pistons in the hydraulic cylinders on my JD loader. I was able to bend them back straight by putting a wood block between the loader arms and the pistons, then use the dump/curl to straighten them. I know the manual tells you not to do that and now I know why. Some things you learn the hard way, so I won't do that again.
/ Learned Something New About Loader #7
I have been doing that for years. When back-dragging you need to change the angle especially at the end to blend the little "pile" of material on the leading edge of the bucket edge to not leave a bump of material so you flatten out the bucket angle at the end of your run to blend it.
/ Learned Something New About Loader #8
the feature is also very handy when using front mounted snow blower with hydraulic chute- - allows you to turn chute while in float.
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
Caterpillar 950L/K Track Loader Service Manuals (A63117)
Caterpillar 950L/K...
2020 Godfrey Marine Hurricane Boat w T/A Boat Trailer . (A61574)
2020 Godfrey...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
KIVEL 3500 PALLET FORK ATTACHMENT (A61572)
KIVEL 3500 PALLET...
2006 International 4200 2,000 Gallon Water Truck (A61573)
2006 International...
