Learned Something New About Loader
/ Learned Something New About Loader #1
rwork
Mississippi Gulf Coast
Kubota B6100 LS R3039H
I didn't even know this was possible until someone posted about their loader not being able to curl / dump while in the float position. I thought about this yesterday while I was grading my drive, and gave it a try. It works! I've had the tractor almost two years, and never knew!
Any other secret tricks??
/ Learned Something New About Loader #2
? I am missing something maybe. You should be able to curl/dump while floating the lift arms. It is a fantastic feature smoothing and grading. Are you saying that yours doesn't?
No, mine does. Just never knew that was possible. Someone posted a little while back, that their tractor was able to do it, but no longer could. I had never even heard of that before.
/ Learned Something New About Loader #4
Oh. Good. Best way to smooth surfaces is back drag with the bucket almost level with a slight tilt up or dump down and used the front edge. Trick is slight adjustments as you finish off not to dig to deep or leave a pile at the end of the drag.
Learn something new every day !
/ Learned Something New About Loader #6
I sure wish I could grade my drive, it's not bumpy, just full of this #$^&## snow again. Can't wait to see the ground again. 23 in. of the white crap on the ground, deeper where there is drifting. One trick I learned not to do is drag backwards with the bucket in the full dump position and the front tires off the ground. I bent both pistons in the hydraulic cylinders on my JD loader. I was able to bend them back straight by putting a wood block between the loader arms and the pistons, then use the dump/curl to straighten them. I know the manual tells you not to do that and now I know why. Some things you learn the hard way, so I won't do that again.
/ Learned Something New About Loader #7
I have been doing that for years. When back-dragging you need to change the angle especially at the end to blend the little "pile" of material on the leading edge of the bucket edge to not leave a bump of material so you flatten out the bucket angle at the end of your run to blend it.
/ Learned Something New About Loader #8
the feature is also very handy when using front mounted snow blower with hydraulic chute- - allows you to turn chute while in float.
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2002 CHEVROLET 3500 FLATBED TRUCK (A64278)
2002 CHEVROLET...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A64557)
2008 21 Ft...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
