Nearly tore the roof off!
/ Nearly tore the roof off! #1
rwork
Mississippi Gulf Coast
Kubota B6100 LS R3039H
Well, I had just finished grading the drive this afternoon, and was about to pull the tractor in the barn. My three point lever felt a little stiff, so I thought I'd spray a bit of grease on the linkage. I had stopped the tractor just outsie of the barn, and I'm standing beside the tractor spraying the grease down on the linkage through the lever slot. All of a sudden I hear this crunch, and realize I've leaned into the joystick, and the bucket came up right under the eave! Bent the gutter busted the fascia, and cracked a few rafter tails. Oh man, lesson learned!
/ Nearly tore the roof off! #2
I know! The Sheit always seems to come oudda nowhere! Usually just when you are feeling too good about yourself it seems!
Tore the Eavestrough off the house alot of years ago blowing snow.
Another time, hacked off the brake lines of my first car with a shovel, getting it unstuck, then drove it through the garage door!
It's all just good fun! Better then getting hurt! But, I did that again two days ago anyway. Once again, totally out of the blue!
/ Nearly tore the roof off! #3
Dontcha just love those Oh Sheit moments?! The door into my shed is 7' high, guess what happens when you forget to fold the 7.5' high ROPS! :banghead:
/ Nearly tore the roof off! #4
Yup, I almost did the same thing inside my garage (8' ceiling), working on 3 pt, turned around and the bucket was about 2' from ceiling! Gotta remember to use joystick lock! :ashamed:
/ Nearly tore the roof off! #5
It's always those end of day 5-minute fixit projects -- which I don't need to do right then -- that cause problems. I'm starting to learn to call it a day when I finish my main project, and not try to squeeze in little extras. They often come back to bite me in the butt.
Speaking of the ROPS, I have folded mine back as well. Before I even started the tractor up, I decided to top off the fuel. My tank is behind the seat, so I have to step up on the box blade, then put one foot up on the tire to brace myself to handle the 5 gallon can. As I stepped up, WHACK! I smacked my head on the folded ROPS!
/ Nearly tore the roof off! #7
Good thing your alright. Must of scared the crap out of you.
Yep, sure did! I've been meaning to clean those gutters out....never thought about using the tractor !! LOL
/ Nearly tore the roof off! #9
Makes me glad I always fold mine all the way down!!
Of course... I also avoid filling my tractor from a 5 gallon can anytime possible!!
/ Nearly tore the roof off! #10
I'm feeling alot better today; thought these things only happended to me!
/ Nearly tore the roof off! #11
It started pouring rain one day and I tried to get the tractor (and myself) into the garage as quickly as possible. I forgot about the ROPS being up. You can fill in the rest. . . .
/ Nearly tore the roof off! #12
Popping wheelies trying to drive your tractor into the garage with the ROPS up probably isn't considered "normal use."
/ Nearly tore the roof off! #13
Makes me think of Oliver Hardy "Why don't you be more careful!!"
/ Nearly tore the roof off! #14
As my wife would tell you, NOBODY has ever considered me normal. :confused2:
(24) Ratchet Tie Down with Toolbox (A61166)
(24) Ratchet Tie...
2017 Ford Escape (A61569)
2017 Ford Escape...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
New/Unused AGT YSRT14 Mini Skid Steer (A61166)
New/Unused AGT...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
