16 x 24 Pole barn planned for the spring
/ 16 x 24 Pole barn planned for the spring #1
IHDiesel73L
I was searching around for plans for a smaller pole barn with a large gambrel roof loft and a thread about something similar on another forum:
http://www.mytractorforum.com/showthread.php?t=42443
He hasn't logged on in over a year so I don't think he's around anymore, but what I did was study his pictures to try to copy the design. He did mention that his would have to pass code-mine would as well since I live in New Jersey, but from what I heard the inspectors are very willing to work with a homeowner that at least has an idea of what they're doing and how to do it the right way. This is the most helpful picture from the thread:
attachment.php
As far as the pole barn portion itself that's all pretty standard, 6 x 6 poles (though I've read that 4 x 4s are adequate for an 8' wall-can anyone comment on that?), 8' spacing, girts 2' OC, etc... Where my design starts to deviate is the second story. It looks as though he used 2 x 6s for his floor joists. I plan on using 2 x 10s. The reason is because as you can see he has a center support girder which I don't want in mine. I looked up the maximum span for a #2 Doug Fir 2 x 10 16" OC and it gives me 14' - 11". The span between my inside eave rafters (I think that's what they're called?) will be 14' - 7", so I should be good there. I'm not sure of the best way to tie in the floor platform up top to the poles though. Obviously I'll nail each joist into all four eave rafters, but I'm thinking that there must be some better way. Here are two different details:
Now the same idea but with a 2 x 10 top plate over the poles as a more substantial nailer for the joists:
Is one really better than the other? Now onto the loft. I want to use a gambrel truss in order to get the most out of the loft space. I'll be using it for a lot of out of season storage so that I can keep the floor space of the barn for equipment and workspace. Again, I basically copied JDA's design from the pictures-here's what I came up with:
It's pretty simple and uses 2 x 4s and plywood gussets. From what I've heard homeowners are allowed to design their own trusses and the inspector will offer guidance if they think it's needed. This is going to be a pretty simple barn-compacted stone dust floor, sliding door, etc... Also I'll be using steel siding and roofing, so there will be girts nailed across the trusses as well. I welcome any criticism or thoughts on the design.
/ 16 x 24 Pole barn planned for the spring #2
All I will add is that 16 x24 seems big when your buying materials and building it, but once you have 2 feet of clutter/stuff/junk on either side, a tractor in the middle, ect; it's fairly small.
/ 16 x 24 Pole barn planned for the spring #3
4x4's are strong enough, but tend to twist and turn too much to be reliable for anything. I would only use 6x6 posts. I would notch the beams into the posts so that the wood is resting on wood. Hanging wood required brackets and bolts. Never use just one or the other. And in some places, bolts alone are not up to code.
I don't think I would try to save a buck on the floor joists with 2x10's. I think 2x12's are well worth the extra expense.
Do not build your roof out of 2x4's!!!! This is going to give you too much movement over time and lead to issues. I like half inch plywood for your gussets. I use liquid nails and deck screws to hold it all together. I don't like nails and try to use screws as much as possible.
Stagger your joints on your purlins. If you set your posts 6 feet apart, use 12ft purlins. If you go 8 feet apart, use 16ft purlins.
Eddie
/ 16 x 24 Pole barn planned for the spring #4
4x4 is more than adequate for 8' wall, but the example you show looks as if he is adding the new loft/roof to an existing shed. And he has that center beam you don't want. Go with 6x6. I assume you are gonna fill that loft with heavy stuff.
/ 16 x 24 Pole barn planned for the spring #5
IHDiesel73L,
Best advice I can give you is to follow Eddie's advice. He is an experienced builder and well respected here. Just for fun I ran 2X10's on a span calculator and I only hit 16" once. That was with Select Structural Spruce-Pine-Fir with 40 psi live load and 10 psi dead load. If you switch to 2X12's you can go 19'6" with the same grade and loads and you can go 17'10" with #2 grade. It's a no brainier, meaning go with 2X12's and you don't have to think about it.:2cents:
/ 16 x 24 Pole barn planned for the spring #6
since your still planning you may want to contact a truss builder for a quote, inspectors love professionally engineered parts and the price might not shock you at all.
Also you may want to check on gluelam's for you floor joists
Makes sense-would it be better still to use 4 x 6s like this?
More on this later.
I like the liquid nails and screws idea-would 2 x 6s be adequate?
FWIW the interior span was only going to be about 14' - 10" (16' would be the exterior dimension), but ****, with 6 x 6 poles and a 2 x 12 supported loft I can put a heck of a lot of weight up there :thumbsup:
I hear you, but I'm not nearly as blessed as most here in terms of land and equipment. I live on a 1/4 acre so I want the most storage without taking up the whole yard. In terms of equipment I've got a small JD lawn tractor, vertical log splitter, generator, push mower, power washer, and other odds and ends. However, the space will also serve as a sheltered spot to work on my truck now and then.
Keep the feedback coming!
/ 16 x 24 Pole barn planned for the spring #8
Well, IH, now that you posted here too, it's easy - just listen to old Eddie. I think that boy knows a bit. And, I didn't tell you over there, but if agree, build that rascal BIG! Believe me, you'll need the space.
A man can never have enough roofs on his place to put all his junque under.
/ 16 x 24 Pole barn planned for the spring #9
An old rule of thumb for any type of pole barn or storage building is to double the size of what you think youll need.
/ 16 x 24 Pole barn planned for the spring #10
In maple syrup production, the rule of thumb is to build your sugar house twice as big as you think you'll need... That way you'll only have to add-on once.:)
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2018 VOLVO DD25B DOUBLE DRUM ROLLER (A62129)
2018 VOLVO DD25B...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
