Solar power anyone ?
/ Solar power anyone ? #101
Necro thread:
Let me ask this:
I have 2 service panels (ie 2 240V service panels, not a service panel and subpanel) in my home. If I feed solar back into one of the panels, does it back feed into both panels or does it just energize the panel it runs into?
/ Solar power anyone ? #102
Necro thread:
Let me ask this:
If your main breakers are both on, it will feed into both panels.
paul
/ Solar power anyone ? #103
paul
Two separate main breakers (ie service disconnect breakers). Is there a way to feed to both panels from one inverter?
/ Solar power anyone ? #104
Necro thread:
Let me ask this:
We really need more info about what you are trying to do and how it's currently hooked up, in order to best offer advice.
Based on your post, here are my assumptions;
1. You currently feed the grid 240vac to the main breaker of both panels. (either that or there are two sets of wires coming from the pole outside, one set to each panel)
2. The reason for more than one "main" panel is to split the building (as in a major reno took place and there was no room to add the additional circuits to the first main panel).
3. You need to have a way to disconnect the grid ac "before" you apply inverter ac or the sparks will fly. :shocked: If you feed "any" other ac source to either of these panels, it will backfeed thru the main breaker to all circuits on both panels. (as well as out to the grid)
What most folks do is feed the grid to the AC IN port of the inverter, and let the inverter choose the whether the grid ac feeds the panels or the inverter ac feeds the panel, based on the serviceability of the grid ac. That way, the inverter power will "sync" with the grid.
More data required!
/ Solar power anyone ? #105
I don't have a system yet. I'm am trying to ascertain what I can reasonably expect from a solar power system. My home has 2 separate main panels. Each panel has a main breaker. By this I mean, there are 2 separate heavy cables entering the house through the wall which originated from the utility company's power meter.
One meter, 2 service panels. If I turn off the main breaker in panel #1, it has no effect on the circuits run from panel #2. The same is true for panel #2 regarding panel #1. There is no cable INSIDE the house that runs from panel #1 to panel #2 ie it is not a master panel-subpanel set up.
So here is my question: At some point, the power is shared BECAUSE the single utility meter reads the power usage that goes to each main panel. Is there a way to wire a solar power system so that only one controller box feeds into my home's TWO main panels or does each main panel require a separate controller.
/ Solar power anyone ? #106
A question back at you, why do you have more than one breaker panel? Is it because an addition was done and the existing panel was too full? What size are each panel, 100 amp/200amp? Your life would be sooooo much easier if you had only one. Not saying its impossible, just easier.
As I said earlier, you cant feed more than one ac source to the panel. You will have to find a way to switch between grid power and solar power. Right now, the grid feeds both panels. What you will need is a switch where both the grid power is fed, as well as the solar power. Then, based on certain conditions, a decision is made as to which power is selected to feed both panels.
You probably should open your own thread, as this one we are stealing from Raspy.
/ Solar power anyone ? #107
2 separate 200 amp panels. The person who built the house wanted a lot of service because he had a full shop, separate garage (with 240V power) in addition to the house. It is nice for adding new circuits (like when we did the kitchen renovation). At this point, there is now easy way to revert to one service panel.
As this was a 4 month old post, I don't really think it would be considered "active" at this point.
/ Solar power anyone ? #108
paul
I think this is correct. Both panels end up at the same electric meter, they are electrically tied together. It doesn't matter which panel you connect the inverter to.
/ Solar power anyone ? #109
That was my thought too. I just wanted confirmation before researching further. Thanks.
/ Solar power anyone ? #110
My home was built in 1977 with two 200 amp panels side by side.
I also have a generator panel that covers 8 essential circuits... so only those eight go through a smaller panel with 8 switches to let me select.
/ Solar power anyone ? #111
Yes. That's how my home is set up. If I run the solar into the gen panel, it would feed both 200 amp panels when the utilities are working and would still function if the generator were powering the gen panel
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63118)
2017 Cadillac...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
JOHN DEERE 4560 TRACTOR (A63290)
JOHN DEERE 4560...
2024 John Deere 5075E Tractor Loader (A63116)
2024 John Deere...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
