new to forum, plus I have limited experience with tractors....
/ new to forum, plus I have limited experience with tractors.... #1
ldman
Mississippi
3055 1973 ford
Hello all,
I have 80 acres mostly in timber. I also own a small manual sawmill that I have been using to cut timber off my land. I plan to build a new shop that will also be storage for lumber I cut, and new sheds for equipment with the lumber from my place. Once I get my new shops and sheds built, I will start to cut lumber for others and sell lumber from the trees off my place. I own an old 3055 ford tractor. It doesn't have hydraulics for a front end loader. So, I'm wanting a new or used tractor with a front end loader. I'll need something that can handle large logs to load on my manual sawmill. Plus I plan on clearing land as I cut timber off my place. So i'll need something big enough to clean up logging ect...
I have looked at a lot of tractors. But my limited knowledge has me confused as to what I may actually need. My 3055 is basically an old ford 4000 with a 3000 front end. There's no place to put front weights on my old ford.... so I often run into not being able to load heavy hardwood logs onto my sawmill.. for the front of my old ford comes off the ground when trying to pick up heavy 16' logs with the forks on the back of my tractor.
What I want is a tractor with a front end loader. It needs to be able to handle heavy logs with either a pallet fork on the front or forks on the back to be able to load them on my sawmill. Plus it needs to be able to pick up heavy stacks of cut lumber to be moved to drying sheds.
research has told me that I'm better off with a 4x4. They run about $5k higher than a 2wd. Do I really need a 4wd? Older tractors such as my 3055 are heavier than most newer tractors. Having fluid put in the tires of newer tractors can offset the weight difference.
I have looked at many tractors. The one I have found that seems to me to be what "May" be best for me is the Mahindra 5530 4wd. It has a much higher lift capacity than any others in it's range.( I'm thinking loading logs ect..)...
Any input is very much appreciated. I have even considered a backhoe/loader since I have a tractor...
What do you guys think I may need???
thanks,
Dave
/ new to forum, plus I have limited experience with tractors.... #2
What dealers are within 50 miles of you.? What is the weight yo want to lift?
Small town mississippi.... Local dealer is ford, John deere, Kubota. Mahindra dealer 65 miles away.
Hello all,
thanks,
Dave
Murphy, as far as the weight, I'm not really sure. I do know that if my 3055 had weights on the front of the tractor, it's possible I may be able to lift what I need.
Edit.... I calculated oak logs 12 ft long with 24" diameter... Around 2800lbs max.
/ new to forum, plus I have limited experience with tractors.... #5
Hello all,
thanks,
Dave
The first thing you need is a dose of reality if your planning on starting a lumber business..
The lumber market is DEPRESSED.
I'm in Fulton (northern Mississippi). I've got about 300 acres of timberland, a lot in mixed hardwood just getting to an age where I can do a thinning for pulp. Back in 2005 we were getting about $3K/acre for good stands of 30+ year old pine sawtimber. We are presently trying to get $2K/acre for a stand of 35yr old pine in Leeksville.
Back in 2005 pine sawtimber was bringing about $50/ton prices/reports/2005/3.pdf now it brings about $28/ton prices/reports/2013/2.pdf.
There are a LOT of loggers trying to pay for equipment they bought in 2005 to 2008. Log trucks around here seem to be mostly rolling to chip plants with the chips being sent overseas. Every time since 2010 that market prices have "blipped" up they go back down QUICK. Trees grow slowly and you can put off cutting for years.
So back to your 80 acres (and 2 mules?).
I've got 2 tractors, my CUT is a Kubota M4700 (~50HP, FEL lifts a ton, 3pt 2 ton) which is probably the size of what you need. My SCUT is a B7610 (23HP, FEL lifts about 700 lb, 3pt about 1300). My sawmill is a Woodmizer LT10. I cut lumber because I need trees cleared and shelving.
If $$ are tight look for a tractor that will carry your 16' log with the 3pt (about 3,000 lbs Timber and Lumber Calculators at WOODWEB )
Get 4WD.
Look at used.
My M4700 w/ ~1400 hrs cost me about $12K last year in January.
The chipper cost $1.7K new.
Good luck and where in Mississippi?
newbury, I'm not in the market to wholesale any lumber or timber at the present time. Thanks for your reply, for you answered a few questions I had. I just want a new tractor that can do what my current old one is unable to do. I want to build a new shop and a couple more buildings. The only logging of timber on my place that will be done is for personal use only for the time being. Once I have my sawmill building up and plenty of storage space, I plan to cut lumber on my mill for locals. I have done few jobs already with my mill... one was a man that wanted some large cedar trees milled, yet he didn't want to pay the local mill yard $75 hour to cut them... I cut them on the halves for him. I got half the lumber. Fine with me, for he had some HUGE cedar trees that produced some nice lumber. Other than that, I've strictly cut for myself. I have very little experience sawmilling. I would however like to get into specialty lumber cutting in the future.
Dave
Get 4WD.
Look at used.
/ new to forum, plus I have limited experience with tractors.... #7
I say look at 50 hp with a FEL capable of lifting 3000 lbs +.
/ new to forum, plus I have limited experience with tractors.... #8
For a logging tractor the 5530 would be a good choice in my opinion...simple with brute strength. I looked into them myself when I was buying. You might also look into the Workmaster series by new holland....also simple and strong.If I had more land and was looking into purchasing a bigger tractor today for logging work I really like the 5e series deere with power shuttle. Pretty good bang for the buck. Power shuttle transmission sure makes log jockeying with the loader much easier.
/ new to forum, plus I have limited experience with tractors.... #9
For 2,800lb logs, you'll need an FEL that can handle more like 3,500lbs at the pins (since the weight is farther forward than the pins, which lowers lifting capacity). Very few compact tractors get into that range, so you're probably looking more at Utility class tractors. FWD will definitely help with FEL work when you have that much weight out front, and you're probably going to need a decent size 3pt counterweight.
For what you're doing, it sounds like a true backhoe would do a better job...way more lifting capacity, and a lot more capable for digging stumps etc, and you can use your current tractor for stuff like brush hogging, etc.
/ new to forum, plus I have limited experience with tractors.... #10
You can get an older model Case 580 backhoe in good shape for 10-12000 bucks. It will handle much more weight than any CUT or Utility tractor. Not too many 4 wd models setting around but I have seen a few and they may be a bit higher than the 2 wd. The contractor whole built my house bought a fairly good 2 WD one for $8K. It is a little sloppy at the pins but good engine and transmission. Lots of them available due to construction slump in most areas. Check out Craigslist.
As for your current tractor, all the ones I remember had 4 bolt holes in the front casting that is just below the radiator. This is where you bolt on the weight bracket. Every tractor above a SCUT that I have ever seen has front weight capability. It may not have the weight bracket on it but I would bet the holes are there.
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
IREV High End Electric Scooter (A60463)
IREV High End...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
STAINLESS STEEL FILTERS (PALLET) (A60736)
STAINLESS STEEL...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
