Help Troubleshoot 1978 JD 400
/ Help Troubleshoot 1978 JD 400 #1
cartod
Northern, West Virginia
JD 4066, 1023
Plowed today for 2 hours, when I went to start it again it turned over and then the electrical system died. No lights, no starter no nothing. Battery checks out fine. Where should I start????
/ Help Troubleshoot 1978 JD 400 #2
Ground strap.
I found a wiring diagram and it shows no fuses but a 25a circuit breaker. I followed the ground from the battery to the engine, looks grounded to me.
/ Help Troubleshoot 1978 JD 400 #4
Check and clean/tighten all FOUR(4) battery cable ends and report back.
/ Help Troubleshoot 1978 JD 400 #6
Sounds like something that happen to me,i knocked off the wire to the electric clutch it was completely dead.get down by the front tire and look under motor where the pulleys are that is where your electric clutch is see if wire is dangling.
I knocked it around real good today pushing snow, Im sure now that I jogged something besides my neck .. thanks, I will let you know what it was. Hoping its easy.
2020 Nissan Pathfinder SUV (A61569)
2020 Nissan...
2022 PETERBILT 579 DUMP TRUCK (A62130)
2022 PETERBILT 579...
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
2012 Volkswagen CC Sedan (A61569)
2012 Volkswagen CC...
2021 Kubota SVL 97-2 Skid Steer (A61166)
2021 Kubota SVL...
