Mowing 72" mmm on 2520? Which one?
/ 72" mmm on 2520? Which one? #1
WarmPepsi
Indiana
Own a 2520 with the 62d drive over deck... Was used to a 955 with a 72" deck.
Have seen many 72" decks for sale, off of 4 series units.. Any way to tell what's compatible? I looked on JD's site and saw one that fits the 4115 will fit. However, the site also only shows 7-Iron decks for 4 series tractors, and the ones I see are not the iron decks..
Any help would be greatly appreciated!
For future owners trying to do this, JD got me some PNs..
LVB25263 is the attaching parts for the 72" deck.
LVB25302 is the front hitch adapter (pretty sure I don't need coming from the 62" deck that already has this)
LVB24962 is the optional lock up kit for locking the Mmm up while using the rear 3pt.
I've ordered the attaching parts and will confirm all when I can.
/ 72" mmm on 2520? Which one? #3
Is that extra 10" of cut really worth giving up the "piece of cake to install/remove" drive over deck??
Greg
Greg
For 5 acres, yeah. I wasn't real fond of the 62" deck... I'd always had the 72's and never had any issues.
Had some belt issues with my 62", that I believe are resolved, but not 100% sure. Wanted a 72 from the get go, but got a good deal on the tractor & loader, only had 62.
/ 72" mmm on 2520? Which one? #5
You piqued my interest with this thread. I have a 62D on my 2720 and the drive over feature is nice. Two things:
1) is the 72" you are pursuing a drive over? Or is it the slide out "C" model?
2) I would really like some feedback on the lock-up kit as it may come in handy in the off season when don't have the MMM installed.
Thanks for any and all input.
Jim
Jim
Nah, no drive over. Have a loader, it picks the front up just fine.
I'm pretty sure the lockup for the 62 is different. The only real difference I can see from pics of the attaching arms is how the one crosses over to pick up the arm to lift the 72" deck.
I'd love to see pictures of any guys with a 72 mounted as I admit, I am doing this a bit blind (trusting JD)
/ 72" mmm on 2520? Which one? #7
It sounds like it may be comparable to the 62C I have on my 2305. Can I get you to post a couple of pictures of you 72 so I can see what you are looking at? My 2305 doesn't have a lock up kit as I bought the hydraulic lift before they offered the bypass valve.
Thank you so much for replying!!
Jim
/ 72" mmm on 2520? Which one? #8
Are the belt issues why you weren't fond of the 62? Curious,because I don't know what's not to like about the 62D.:)
Greg
/ 72" mmm on 2520? Which one? #9
Lock up kit is the same for both decks. Should be different because of the weight difference is hard on that kit. Brackets bend and turnbuckles break. I'll post a picture of the 72". Having had both, the 62" and 72", the 72" is the better mower if you have room for it in your yard.
/ 72" mmm on 2520? Which one? #10
Greg
You bet. At an actual 73" cut and large yard this deck took 45+ minutes off mowing time. The deck is not hard getting on and off plus most users probably never take it off during the season.
Greg
Yeah. Having never thrown a belt in my life, and throwing 4 in one season; that's enough to piss anyone off :). First one ill credit to dull blades and just running it... Like I always did. Second one, I dunno.. Possibly wrong belt from JD. Third, right belt from JD... Under 3 hrs of mowing time. 4th was done aftermarket brand... Lasted like 7-8 hrs. Finally for the 5th belt, I got one like 1 1/2 - 2" shorter than what I needed.. Tensioner had brand new spring after first belt went, but belt would stretch, and it ran out if tension, would go.
This one shows good after 15 or so hours, tensioner all good. Plenty of travel left. So like I said, I think I've got it sorted out, but not swearing by anything...
Also, from past experience, the 72's clean themselves out a lot better than this 62 does. It needed washed out all the time or I'd have grass clumping and almost burning along side the blades.. Just didn't like that idea. I mow probably 3.5 to 4 acres, and any time saved is great.
/ 72" mmm on 2520? Which one? #12
/ 72" mmm on 2520? Which one? #13
Thanks PCABE5. Looks a lot like a 62C, just heavier duty. The gage wheels are similar to the 62D. Do the rear wheels pivot 90 degrees to allow you to pull it out from under the tractor?
/ 72" mmm on 2520? Which one? #14
Would this one fit your needs? I don't use a MMM any more because I bought a 72" F-935 front mower at an estate sale. And, I got an 84" rear mower for field work. The extra width gives you more 'reach' around trees and bushes that the tractor wheels interfere with.
I'm a little east of mid-Michigan. I have all the brackets and covers, etc. Its in pretty good condition. Has been sitting in the back of my machinery shed for 8 years or so. I have the belt drive covers off to show the underlayment.
/ 72" mmm on 2520? Which one? #15
The wheels do pivot. The wheels are different than my old 62D.
/ 72" mmm on 2520? Which one? #17
Those pics help a ton, but I'm still having some difficulty after I got the attaching parts.
Any chance you can take a measurement between the rear pickup points on the mower?
Mine seem too wide to fit with these brackets.
Thanks a bunch
I'll take some tomorrow.
/ 72" mmm on 2520? Which one? #18
Thanks a bunch
23 inches outside to outside.
/ 72" mmm on 2520? Which one? #20
The model number on the label says, 72" deck 4115. As the deck is only compatible with the 4115, 2520, and 2720. Will probably fit the 2032R as well. Owners manual is OMLVU14211.
