Home-made attachments...
/ Home-made attachments... #1
ferrari99
Gold Member
Australia
Kubota BX2200, Ferrari 340
Any one who has made any attachments and would like to share them with the rest of us please do, I want to see them. :thumbsup:
/ Home-made attachments... #2
Can't take a photo right now be we have made one that works good. Its a heavy roller for 3 point. Used a crossbar that goes on the lower two arms, and a 55 gallon drum. Cut the drum to the width of the crossbar, filled with concrete, and let it set. Its a roller, and it weights 800 pounds! My dad was a structural engineer so he was able to figure out the cubic inches and how much it would weight. Between him and I we don't have a front loader on anything but it would probably make a good counterweight/ ballast as well. We have been quite impressed with it!
/ Home-made attachments... #3
I hope you get lots of stuff posted here. This is where all kinds of ideas come from.
This is my LPGS built in the spring of 2010.
/ Home-made attachments... #4
I made a box blade that I use to level the driveway in the spring and move snow in the winter.:thumbsup:
/ Home-made attachments... #6
Question: where did you purchase the cutting edge? Also, how far did you drop the edge below the frame?
Nice land plane by the way.
/ Home-made attachments... #7
Started this thread yesterday: http://www.tractorbynet.com/forums/build-yourself/300969-good-landscape-rake-cheap-part.html
This rake is just for pine needles and any leaves that happen to get mixed in. It was also to prove I could do it.
Here's my initial entry:
Back in December I saw this thread Good landscape rake - cheap. To summarize, if you don't want to read this thread, member RedDirt built a landscape rake from hay rake replacement teeth, a piece of pipe, and some angle iron. I decided I could do something similar and attach it to my King Kutter carry-all. Here are the results:
1) View attachment 355124 2) View attachment 355125 3) View attachment 355126 4) View attachment 355127 5) View attachment 355128 6) View attachment 355129 7) View attachment 355130
Pictures:
1. Yard rake on saw horses
2. Close-up of the rake teeth and clamp
3. Tractor with Carry-all on.
4. Tractor with rake - side view
5. Tractor with rake - back view
6. View of clamps on Carry-all
7. Closer view of clamp.
Parts:
1. Rake teeth 15@ $1.99 each
Herschel Adams Universal Rubber Rake Teeth T16-0182 by Herschel Adams for $1.99 : Rural King
2. Steelworks 4-ft x 1-1/4-in Plated Steel Perforated Angle 1@ $14.08 View attachment 355131
Cut into: 2 - 5 inch; 2 - 19 inch
Shop Steelworks 4-ft x 1-1/4-in Plated Steel Perforated Angle at Lowes.com
3. Steelworks 3-ft L x 1-1/4-in W x 1-1/4-in H Plated Steel Perforated Square Tube 2 @ $17.24 View attachment 355132
Shop Steelworks 3-ft L x 1-1/4-in W x 1-1/4-in H Plated Steel Perforated Square Tube at Lowes.com
4. 5/16 bolts, 2?ス" long, qty: 15
5. 5/16 bolts, 5?ス" long, qty: 4
6. 5/16 bolts, 2" long, qty: 4
7. 5/16 nuts, qty: 23
8. 5/16 lock washers, qty: 30 or so
9. 5/16 flat washers, qty: 60 or so
10. 5/16 fender washers, qty: 4
Construction:
1. The two 19 pieces of angle were used to hold the two square tubes together. Four 5/16" - 2" bolts were used to connect the pieces. I had to adjust these as I put the teeth on.
2. The hay rake teeth were spaced every 5 holes on the square tubes. The spacing of the holes on the tubes and angle iron were 1 so that the teeth are space at 5 intervals. The hay rake teeth also have a slight dogleg bend at the bottom and I made sure they all faced the same direction. The flat washers and lock washers were used to take up some space between the bar and hay rake teeth as needed. Except for tines that were on both the angle and square tube every other tine was double lock washered and used 4 flat washers.
3. The 2 pieces of angle iron cut 5" long, the 5/16 bolts - 5"??ス??ス long, 4 fender washers, 2 lock washers, 2 5/16 nuts were used to make clamps to hold to the King Kutter Carry-all. The clamps were spaced to fit the carry-all.
4. The rake was connected to the Carry-all with the dogleg of the tines facing inwards toward the tractor.
Performance:
I determined how low I wanted it to go and set the stopper on my draft control to that. To try it out I used it on some pine needles that were on a slope. Results:
1. The rake was pulling the pine needles along, but it was also digging into the ground. I'm going to try flipping the rake 180??ー so that the dogleg of the tines faces away from the tractor.
2. After the tines had raked all the needles it could rake I needed to lift the tines out of the pile, but the Carry-all would not raise it high enough. This is just due to the dimensions of the Carry-all. To fix this I'm going to have fabricate a 3 point hitch that will allow me to lift it higher. I will post pictures of that when I get it done. The plan is to use angle iron.
/ Home-made attachments... #8
Here are the pictures that just showed up as links in the post above.
01 Rake on sawhorses.jpg 02 Closeup of hay rake teeth.jpg 03 Tractor with carry-all.jpg 04 Tractor with carry-all & rake - side view.jpg 05 Tractor with carry-all & rake - back view.jpg 07 Tractor with carry-all & rake - back view even closer up.jpg 06 Tractor with carry-all & rake - back view close up.jpg
/ Home-made attachments... #9
Bought flat cuttig edges for a 5' back blade from tractor dealer ( now out of Biz ). They are 3/4" below skids.
/ Home-made attachments... #10
I made this for cleaning up tree branches after felling a tree. The tines can float to follow terrain or be arrested. I cut off part of my finger when pulling this thing off in the dark and finding it had a nasty pinch hazzard on account of that floating design.
/ Home-made attachments... #11
Works well this time of year.....I built it so I wouldn't need it...BobG in VA
you know, I used to know how to add an attachment to this site, I guess its been changed...oh well....
/ Home-made attachments... #12
Driveway drag
Rock Bucket (I use for manure and firewood more than rocks) actually I didn't notice till after I posted but the pic is the first generation, the rebar tines did not work, broke off under heavy use. The second generation I used 1 1/4" 4140 round rod, have yet to brake one of those even on the skid steer.
Receiver Hitch that attaches to forks
Also built but no pics at the moment
Bale spear for the loader mounts, gain a couple hundred pounds lift be removing the bucket
10' Boom Pole for the loader used to set trusses on a couple of pole barns.
Ripper tooth for backhoe, use mostly for ice removal in my livestock paddock areas during the winter.
3 point wood splitter
3 point trailer mover
/ Home-made attachments... #13
Goodness..... Things I have built....
None are fancy.... Useful, but not pretty... I know I'm the worlds worst painter... But I don't care...
Enjoy
/ Home-made attachments... #15
I've built several, some good, some not so good.
/ Home-made attachments... #16
Here are a few I have built and am currently building a new 3ph roller and adding tail wheels to my Gannon box for laser leveling.
/ Home-made attachments... #17
Hey jenkinsph, how do you post pics that size that can also be clicked on to enlarge?? I like that wayyyy better than how I'm posting mine. Thanks!!!
Nice build. And a very nice tractor don't see things like here in oz.
/ Home-made attachments... #20
I am using the TBN manage attachments set up which stores the images I have on file so that I don't have to download them each time. Go Advanced and scroll down to Manage Attachments and follow the instructions.
