HTP Invertig 160 DC
/ HTP Invertig 160 DC #21
Hi Jeff!
I see this is your first post here on TBN. Just wanted to welcome you aboard.:thumbsup: You sure have great reputation for taking good care of your customs!:cool:
/ HTP Invertig 160 DC #22
Like I said, "Seriously mis-informed". I'm sure Mark will be by shortly to apologize.
/ HTP Invertig 160 DC #23
I'm wondering if all said above would suggest that Italian Inverters are better than Chinese inverters? That must be the belief or there would be no controversy. I know some of the Chinese Inverters have bad reputations but I once sold a line of Italian Inverters and when we pulled the covers off of 4 identical 150 amp units, They were all very different inside.. just sayin.
/ HTP Invertig 160 DC #24
Orezok give it a rest already. Mark has nothing to apologize for and he wasn't "seriously mis-informed". The machine was discontinued and he wasn't sure about a replacement or where it was made. There is nobody on the planet that knows what every other manufacturer is doing or where they source their machines.
/ HTP Invertig 160 DC #25
Well, let痴 set the record straight. None of the MIG Welders, TIG Welders or Plasma Cutters HTP America currently sells or has ever sold were ever made in China. The machine in question has been discontinued - the main reason it was discontinued was we found most people who purchase a TIG welder want to weld aluminum. A DC TIG machine will not weld aluminum. It was not replaced with anything and it was certainly not replaced with a 130/140 amp machine from China.
Different HTP products are built in different countries. The Invertig 160DC was built in Italy. The PC boards were designed and built in house. The PC boards were not built in China and then sent to Italy to be installed in the machine.
That makes sense. The only people I know who tig steel are either artists or work on exotic automobiles of one kind or another.
/ HTP Invertig 160 DC #26
Mr HTP:
Sorry to hijack this thread, but while I have your attention -- I own a MIG 160 DV, great machine, but my welding needs have gone beyond what it can easily do. I have $$'s burning a hole in my pocket like .035 wire with 200 amps through 24 gage, Anyway, I want to buy a HTP Mig 2400, but I see they are out of stock? When do you expect that situation to be rectified (pun intended)?
/ HTP Invertig 160 DC #27
Sorry mark for the attacks! Your info has helped me tremendously in previous posts of the past, I hope you keep your good work up! You can't please everybody.
/ HTP Invertig 160 DC #28
No disrespect to you Jesse, but you need to go back and re-read Marks posts. He was first to "attack" HTP by wrongfully stating that they were "from China". This has been clearly demonstrated to be UNTRUTHFUL!. All I did was to call him out on his attack on HTP and his failure to acknowledge it.
/ HTP Invertig 160 DC #29
I'm sure mark wasn't demeaning Chinese units if he thought it was from China because he represents everlast which is a Chinese unit, if he misquoted I'm sure it was a simple mistake , however I will reread previous posts.
/ HTP Invertig 160 DC #30
I am sure we all have our ignorance moments:D
The other day I was reading at the Everlast Forum I saw this thread :laughing:
/ HTP Invertig 160 DC #32
Does that mean I am welcome to play with that 1937 idealArc :cool2:
/ HTP Invertig 160 DC #34
Geez, enough already. Do you not understand that someone that has a lot of knowledge can make an educated guess about something and it not be a lie? Are you always this rude?
I appreciate what Mark contributes here, I learn from the dialog from him and others. And when there is something that is being discussed, it's ok if someone contributing doesn't have everything 100% right. All anyone can do is to give their informed opinion, and it is of benefit to the readers of the forum.
Assuming that you are honest, you will admit that you make mistakes occasionally based on your best judgement. That hardly makes one "attacking" or "untruthful". It is, however, untruthful to state a motive to what was said where there wasn't one demonstrated.
/ HTP Invertig 160 DC #35
Like the teacher use to say "If you don't know the answer make an educated guess"
We all appreciate the advice we get from Mark
/ HTP Invertig 160 DC #36
Not to be mean, but I think it's an issue with reading comprehension...either that or there is a chip that someone is carrying around that is mighty heavy. That is all I am going to say about the issue, unless someone wants to get back on topic.
IH IC70-2 RUBBER TRACKED CRAWLER CARRIER (A65056)
IH IC70-2 RUBBER...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
2014 KOMATSU PC170LC-10 EXCAVATOR (A65053)
2014 KOMATSU...
2018 PETERBILT (A68134)
2018 PETERBILT...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
Ford Tractor (A64911)
