Fun with the loader tonight - pallet fork test
/ Fun with the loader tonight - pallet fork test #41
It would be loads of fun. I don't take to heart when I lose, now will I gloat to much if I win.... Lol
:-/. Jk..... Swing on by anytime.
The thing that would worry me is the H-DS giving you an edge in speed under heavy load. If it was a narrow loss I'd console myself by remembering the savings. If I lost too bad I'd probably have to switch colors, I wouldn't have a choice.
Seriously though this idea has merit. I'm envisioning youtube videos and an official sounding name like the Michigan Redneck Tractor Test Lab.
/ Fun with the loader tonight - pallet fork test #42
My rear tires are loaded with beat juice. Im not sure if I have ever hit the relief valve or at least I dont think I have! This is my first tractor and I have put about 100 hours on it so far. I know I am a newbie and have no other expedience with other tractors other then test driving them but I wasn't overly impressed with the lift capabilities of my Ls! I love my tractor and I know I made the right choice just maybe my expectations are a little high?
/ Fun with the loader tonight - pallet fork test #43
I've tried all rpm. How do I check my pressure relieve valve? Sorry I just realiezed im steeling someone else post! Thank you for the help!
/ Fun with the loader tonight - pallet fork test #44
If it is still under warranty, let the dealer do it.
If not, ask in the LS forum.
/ Fun with the loader tonight - pallet fork test #45
Moreso than the results of the test, I'm impressed that you guys willing to brave this weather to conduct the test!! I would have been looking for the fastest way to unload that pallet and then get back to the fireplace!
/ Fun with the loader tonight - pallet fork test #46
This here is 43 bags (40lbs ea on the same pallet as earlier). I here have 34" forks and they don't have the same heavy duty cage as TSO.
I lifted it approx 2'. I was at 27" but since my driveway begins to slope, this can only be a best guess. I stepped out of the tractor and the rear end was light. I could lift it with two hands (could of got dangerous here). I then went And connected my rotary mower. Wow, much more stable. However, 43 bags is NOT a working load for this. This was just a test for MAX load and I would not drive about this way.
Not wanting to overdue things, I threw ten bags on a separate pallet. Lighting, and transporting the remaining 33 bags (1320lbs + pallet + forks + quick attach plate) was extremely comfortable on various pitch ground. I should of tried various weights for transport but I was in a crunch for time.
/ Fun with the loader tonight - pallet fork test #47
Forks used in above test
we were using a heater, aka alcohol ;)
/ Fun with the loader tonight - pallet fork test #49
The one time I really pushed the limits of my loader was when I cut down some walnut trees on my land. I was impressed with the weight it handled. Not sure how much the biggest log I moved weighed, but with my 6' brush hog on the back my tractor would not move unless it was in 4wd. These things are rated much higher to about 4' than to max height (which I didn't know until I moved those trees).
/ Fun with the loader tonight - pallet fork test #50
Play it safe use a calculator. Google "forklift capacity" to find more charts.
Rightline Equipment, Inc.
/ Fun with the loader tonight - pallet fork test #51
Kubota L5030HSTC with LA853 loader with q/a that pushes out a bit and hla 42" forks w angle block in rear to space q/a bracket to right angle. Tires ballasted.
Will lift a 1998 Geo Metro 4 cylinder auto 2dr with 4 spare tires inside to 6" with curl circuit, not the boom circuit. Forks inserted from the side.
Will lift a 4x8 6" thick concrete slab to 2-3 ft
Will not lift a 6x8 ft 6" thick concrete slab completely.
Will lift I think it was 42 8" concrete blocks and pallet from 1 ton truck. (not a full pallet)
MF 5455 with Quicke 750 loader with euro q/a and hla 42" square tip forks
1998 Geo metro to full height
6x8 x 6" slab to full height (well as high as I dared)
14 ft Knapheid flatbed to full height
Full pallet of block
The only think I've not been able to lift with the MF is a volkswagon sized rock in a field behind us.
Kubota used to publish charts showing the lift rating per height, I think the LA852 was the last model with that chart freely published.
/ Fun with the loader tonight - pallet fork test #52
Fallen Pecan tree with root ball still in the ground. Put my forks under the trunk near the base, just to see if maybe I could pop the root ball up that way. I didn't figure it would work, but what the heck it only took a few seconds to try it. Of course it didn't work. Loaded rear tires popped up off the ground quicker than I thought. Didn't have any other counterweight though.
xtn
/ Fun with the loader tonight - pallet fork test #53
2014 LS 5020C with loaded rear tires and a LL5100 loader rated at 2650lbs at the pin will easily lift a ~1860lb payload. 42" HLA heavy duty forks with skids the quick attach. Haven't tried anything heavier yet. P.S. It lifted this from various heights to max height and curled any time all at idle . no other counter weight other than the loaded tires.
/ Fun with the loader tonight - pallet fork test #54
One other thing to think about, is how you pick something up with your forks. I have only a little over 1400 lbs of lift capacity but over 2600 lbs of curl ability. I have noticed if I try to pick up a rock that I cannot lift, I can often curl back all the way, shifting the rock back more towards the pins, and then will be able to lift it up and drive off with it. So if you have a pallet you cannot lift straight up, off the ground, try to curl it back all the way (if the load is stable enough and will not spill over the mast backward) and then try to lift it. Often it will make a difference.
/ Fun with the loader tonight - pallet fork test #55
Yep great point... I am finding the power is in the curl vs. lift when 'screwing' around with stumps, etc. I rolled a huge stump (that an excavator cleared) with my little BX by curling and pushing. Could have never lifted it.
/ Fun with the loader tonight - pallet fork test #56
A little photo op this afternoon with TSO
/ Fun with the loader tonight - pallet fork test #57
Reminds me of an old western movie! :laughing:
/ Fun with the loader tonight - pallet fork test #58
Lifting Heavy
As everyone has said, the farther back the better
A little extra help - Curl bucket - relax curl and lift - repeat until you have the height needed.
The bucket going down lets lift come up. Try it, just a little coordination needed.
Lifting Heavy
The point was NOT too cheat, but to see what they could handle on a pallet, evenly distributed.
/ Fun with the loader tonight - pallet fork test #60
I did not consider it cheating. Just a normal way of using the FEL to the max.
My little guy is only rated at 1,750, by rolling & lifting it has managed about 2,000# up to flat bed height.
1999 Ford F800 Dump Truck, VIN # 3FEXF8019XMA05457 (A65563)
1999 Ford F800...
Golf Cart (pictures to come) (A62679)
Golf Cart...
Stout Buckets XHD84-6 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2024 CATERPILLAR 299D3 XE SKID STEER (A65053)
2024 CATERPILLAR...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
