I'm screwed
/ I'm screwed
Gentlemen! Sorry to get back late, but I feel all warm and luv with all the sound advise and responses.
I agree, I need more than just welding, I need to do some metal fabrication here.
1/ I need to fix the blower housing, it's worn down through, I need to weld it shut.
2/ I'm going to weld a 1/4" thick by 2" wide on the top across the length of the blower. Then drill new holes for cutting edge.
3/ Get a new cutting edge.
4/ Get new skids.
I notice that these skids wear down so fast. Is there a modification some how to slow down the quick wearing down? Some type of Teflon, plastic shoes over the skids?
The good news. A friend has offered to help with his welder. All I need now is get some steel bar.
Once again, I really appreciated the helpful insight of all difference choices of welder. I think I'm going buy one in the future, base on the info I have here it will help me pick one.
I hope I will have time to be back and post some pictures.
/ I'm screwed #22
on my old farmking blower, i installed weld on case hardened adjustable shoes inplace of the factory drag steel. They looked good after 8 years of hard use. I got mine at JD dealership for about $25/each way back when.
i also had to add bracing on the interior 3 rotator blades and wedges on my main auger cause they just kept bending. i got tired of straightening them out. skid.jpgskid shoe 1.jpgrepairs.jpg
/ I'm screwed #24
Whatever you do get, make sure you get some scrap metal and spend an hour or so doing practice beads, especially since you say it's been a few decades since you did any serious welding
/ I'm screwed
i also had to add bracing on the interior 3 rotator blades and wedges on my main auger cause they just kept bending. i got tired of straightening them out.View attachment 353659View attachment 353660View attachment 353661
Wow, that's a beauty, I like it a lot.
/ I'm screwed
Seems like yesterday :)
/ I'm screwed
Re: I'm screwed.
Some progress.
Bought 2 pcs of stock steel bar 1/4 X 2" X 5 FT
Couple pictures.
/ I'm screwed
Next.
Drill holes and attach the second steel bar. Using this as a cutting edge.
Remove the blower off the tractor so my friend can do some welding on the bottom.
BTW, I bought a cheapo HF 70 AMP Arc welder. Can't wait to see if it works.
Retro-fitting the skids.
/ I'm screwed #30
Next.
If you need anything else welded, let me know.. I live just outside Albany.. I'd be happy to help..
