Insulating a wood sided shop?
/ Insulating a wood sided shop? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
We have a ~25x45 lean to on the barn that we use as a shop. It has a concrete floor, loft and a big rollup door.
I need to insulate at least the 3 outside walls and the roof. The two ends are 2x6 studded walls on 16" centers (both ends were done when we added the rollup door and the floor) with T111 for the skin, the other (long wall) is post and beam (doubled or tripled rough cut 2x4 posts every 6-8 feet) with vertical tongue and groove boards. Roof is shingles with plywood decking over old 1x10(?) deck boards and trusses under that.
Currently the only heat is a kerosene salamander, we have a woodstove that we will be adding at some point. I have access to a bunch of foil bubble insulation (~12' tall roll, white on one side, shiny on the other).
My first thought was on the ends (which have 2x6 studs every 16") wrap the studs with either the bubbles or tyvec from the inside (ie around each stud), then insulate it with fiberglass and add plywood to all the walls.
On the sides, I was thinking of 2" foam board between the posts and sealing that with spray in foam.
On the other hand, a friend got a bunch of this a while back and put it above his shop with good results: Foam Board. Polyiso. Delivered available. I could put that over the studs/posts and seal it with spray on foam.
My end goals are:
1. Insulate the shop enough that I can fire up the stove and keep it at a comfortable temperature (unlike now where 15 minutes after I shut the salamander off its freezing)
2. Get plywood up on all the walls so I can put up shelves
Edit: I saw http://www.tractorbynet.com/forums/showthread.php?t=299549 but didn't want to clutter up that thread...
Any thoughts?
Thanks
Aaron Z
/ Insulating a wood sided shop? #2
My shop used to be a hay shed, as in roof and no walls. I put up purlins and steel on the outside, and later had foam sprayed in. I use a wood stove to heat it currently. It is 30' x42'. The wood stove will keep it about 50*f while it's around -10*f outside. My propane salamander was too loud. I think the spray in palm, although higher initial cost, is the way to go.
/ Insulating a wood sided shop? #3
Btw, my shop after a day of being heated, stays warm for several hours.
/ Insulating a wood sided shop? #4
I insulated with polyiso. Great stuff but not worth what they are asking. I paid $5 per sheet for mine.
I'll ask my friend what he paid. IIRC he had a 6x10 trailer stacked pretty high with the stuff and he went to Buffalo to pick it up, so he may have gotten a discount.
Aaron Z
/ Insulating a wood sided shop? #6
FRP Shop - Polyisocyanurate (Polyiso) Insulation Board
Yikes! That stuff ain't cheap new. I thought $19/sheet for 2" sounded high, but I'm not sure about that if it's in good shape. No cracks, corners in good shape, etc.
For reclaimed, I'd want to supervise what goes into my load and have a good idea of what dimensions are needed after you cut it to fit. If you would be ripping it for example, and will have a scrap edge anyways, then a dinged edge on one side is not a big deal.
He paid $19/sheet for 2.5" insulation, he selected what went onto the trailer.
Aaron Z
/ Insulating a wood sided shop? #8
I don't know how representative the prices are on the site I linked, but the 2" styrofoam is $14-$15 per sheet more than I paid in 2006. That's why I said Yikes! :laughing:
Its $32ish for a 4x8 2" thick Polystyrene sheet at my local Lowes (R5/inch vs R6), so $3ish off of the 2" sheet would put him at 1/2 the price of new. I may go that route, glue it to the studs/posts and screw through with long sheetrock screws to add the plywood...
Aaron Z
/ Insulating a wood sided shop? #11
Fiberglass batts are the cheapest way to go. R-19 fits in the cavity of 2 X 6 studs, available in 16" center and 24" center stud spacing. It has a vapor barrier face. On the walls w/o studs Just add non-load bearing studs on 16' centers. 2 x 4 ok just set out at 5.5" from the existing wall to their face. Then you have a way to add sheeting and/or shelves to the walls. R-19 is the energy code minimum any where where codes are enforced.
Ron
/ Insulating a wood sided shop? #12
No offense, but from the described build out of your shop; your biggest problem is going to be air leaks. You need to stop cold air from getting into the building. It will come in everywhere. From places you don't even think air would go through even. Spray foam may seal up leaks, but it needs to be covered for fire rating purposes. I prefer to use dense pack cellulose whenever possible. I'd invest a little time into tightening up your shell and making sure you have no water issues in the walls or T1-11 first and then insulate. Fiberglass does nothing for stopping air infiltration by the way.
I have noticed the air infiltration. On the old (long) wall there are 30+ knotholes that I have found. No water leaks on any walls that I have found though.
How well would it work to wrap the inside of the studs and posts with Tyvec (or similar) after filling all the knotholes/cracks I can find with foam and/or calk?
Covering foam wont be an issue as I plan to put plywood over the walls at ~8' and put something else (sheetrock? metal roofing?) over that.
IMO when the ends went on, they should have covered the walls with Tyvec.
Aaron Z
/ Insulating a wood sided shop? #14
When I did my pole barn, after I filled between the posts with foam sheets (and spray foamed the gaps/holes) I covered the whole walls with sheet plastic to both stop air and provide a vapor barrier. Then I covered it with used T-11 and new OSB. I think to make the insulation worthwhile, you need the vapor barrier and then it's common sense to put something up as a fire barrier.
My polyiso was salvaged from a commercial building roof. At the roofing company, I could sort through the piles and take what I wanted (1.5" and 2" thick) for $5 a sheet. It had the attachment holes to be filled and minor edge damage. In the last few years it's been available at that price several times but I haven't seen any advertised lately.
As I see it, either way, I will need to wrap the existing wall in tyvec or plastic to keep the wind out of the cavities, that's $0.06/SF (plus tax).
If I then put in R19 fiberglass, a 9 pack of Kraft face is $0.52/SF (plus tax), but I would need to stud out the long wall every 16" or 24" ($$$$).
If I put in foam (R15), I can put it over the top of the posts or studs (faster install) and it would be $0.59/SF (plus tax and foam), HOWEVER, it should insulate better as air infiltration should be nil.
If I really wanted to superinsulate, I could backfill the foam with blown in cellulose for an extra $0.30/SF on the 2x6 stud walls and $0.20/SF on the 2x4 post walls.
Guessing here, but the end walls are probably about 520SF between the two (once you take out the window, the man door and the garage door) and the long wall is ~480SF.
So, if my SF measurements are correct, it would be $1270ish to put tyvec on the walls around the studs, insulate the walls with foam and backfill with cellulose (assuming 200SF of wasted foam and $200 in spray foam, calk, etc).
I need to look at the roof and see how the trusses go together, if they are single, I might put foam between them and glue it up, then add braces every 4 feet (1 at each end and 1 in the middle) or something.
Aaron Z
/ Insulating a wood sided shop? #16
What is the spacing on your trusses? If it's 4 feet, you can directly attach metal panels and then blow insulation above it. The ceiling is more important than the walls if you want to heat it. I covered it with plastic, added the metal liner panels and then blew in cellulose. Not too expensive and very effective.
For vapor barrier on the inside of the walls (between heated space and insulation) you should use plain old plastic sheeting, not tyvek. Tyvek breathes and should be used on the outer surface before siding if you are replacing it.
I think its 4 feet. The complication with the roof is that there is a 8' wide loft on the end next to the barn and I still need to be able to get in from the side...
Here is a picture of what I am thinking of doing now:
From the top down (outside in):
Green with a black border is the outside T1-11
Blue with a black border is studs/posts
Red is Tyvec
Yellow is blown in cellulose
Orange is plastic (needed with foam?).
Purple with a black border is foam insulation
Pink with a black border is the inside wall covering (plywood for the first 8 feet, then possibly sheetrock or metal).
Does that make sense? Any suggestions on changes? I suppose I could skip the foam and just fill with blown in Cellouse, but then I would need to stud out the long wall...
Thanks
Aaron Z
/ Insulating a wood sided shop? #18
I keep going back and forth on insulating the barn, but I think no matter what I put in the mice will love it.
/ Insulating a wood sided shop? #19
You don't need to go overkill on the walls other than to stop any air leaks. The ceiling is where you will make the most difference.
If on a budget, I would simply go the cheapest way on the the walls and super insulate the ceiling.
/ Insulating a wood sided shop? #20
As Kenny mentioned, Tyvek breathes, which makes it an AIR barrier but NOT a VAPOR barrier. Plastic is BOTH, because NOTHING passes it (unless you make LOTS of holes in it :) )
Here's the main thing to watch out for - when you heat a space, the moisture in it wants to leave - water vapor is so fine it will go thru pretty much ANYTHING that isn't non-permeable. So the moisture in the room tries to exit thru anywhere it can.
Rule of thumb for occupied spaces is that the vapor barrier goes toward the HEATED side, in order to prevent moisture in the wall or ceiling - so in Florida, a vapor barrier would go on the OUTSIDE of the wall but in your area, you want it on the INSIDE.
MOST IMPORTANT - you NEVER want more than ONE vapor barrier, because in the REAL world, moisture WILL get into the wall at times - so if you accidentally end up with something that works as a vapor barrier on BOTH sides of a wall, that pesky moisture that makes it into the wall (one way or another) will get TRAPPED inside and will cause rot, mold and mayhem.
By limiting actual VAPOR barriers to ONE side, the wall can eventually dry out inside, which is what you want.
For normal house materials, even a good coat of latex paint will act as a vapor barrier, as will "trailer trash" plasticized paneling. Paper or foil as used on fiberglass batts is also a vapor barrier, especially if it's installed according to directions (overlap the backing on studs for a continual surface) - Foil on the foam insulation is the vapor barrier, so if you use that and cover the SEAMS with foil tape, that's your vapor barrier.
On the "vintage" side, tar paper on the OUTSIDE, if overlapped like shingles but NOT sealed, works as an AIR barrier but allows breathing - so it would work similarly to Tyvek.
Point being, if you're aware of what DOES act as a VAPOR barrier, just make sure you only use those materials at the INSIDE of your walls and use BREATHABLE stuff elsewhere, such as Tyvek for an AIR barrier on the outside.
I purposely didn't try to tell you exact materials to use, only an idea of which ones work where and why. I've seen enough of your posts to know that's probably more than you need :thumbsup: ... Steve
