Front turf tires for YM226
/ Front turf tires for YM226 #1
Torx
Hernando, MS
Yanmar YM1500 and YM226
Hello Board,
I recently bought a used YM226. It has rear diamond turf tires already installed The tires on the front are Ag 3 ribbed 5.00-15. The specs I have seen say it should have 6-14 Ag ribbed tires.
I am not sure why it has the 5-15 tires in the first place.
Can a turf style tire be purchased for the existing rims?
Or do I have to buy new rims to fit new turf tires.
An online tractor parts supply house has rims and tires for $573 plus shipping and says they will be an inch shorter than my 6-14 stock tires and wheels. Am I going to end up too small for mowing?
I don't have an FEL so steering isn't a problem that I know of. I will be mowing for the most part.
Do I search local tire supply houses and do I just tell them that I have 5'' wide by 15'' diameter rims or does the 5.00-15 on the tire compute to another size altogether?
I hope I'm not asking a silly question. My ym1500 has 8.5/8.00-22 rear tires and I know that the rims are larger than 22''.
Any good places to look)
Thanks,
Torx
/ Front turf tires for YM226 #2
I don't think you will have much luck finding a narrow 15" turf tire,but you could use a car tire.Measure the diameter of the tire and look up 15" tire specs. They are all a little too wide,but will work.Example- a 155/60/R15 is 22.3"diameter by 6.1 wide.
You measure the diameter of a rim from bead seat to bead seat-don't include the lip.
Thanks. I have a questionable left front and hate dropping $600 for new rims and tires.
I'll check the website as there are some really close ones.
And a car tire or small trailer tire might be a good alternative as well.
Thanks'
Torx
/ Front turf tires for YM226 #5
/ Front turf tires for YM226 #6
5.00 - 15 farm implement tire is a reasonable alternative. Broad, smooth tread with grooves. And it will fit the same narrow rim as a 3-rib 5.00 - 15. I see them about $100 each on Ebay.
Is a farm implement tire designed for a farm implement like a hay loader or will they work as tractor tires? I hope this isn't a silly question.
/ Front turf tires for YM226 #8
They should work as well on a 2 wd tractor front as on an implement. You will probably use the brakes more for sharp turns on mushy ground but I wouldn't mow when its that wet anyway. This seems like a simple solution that keeps your existing 15 inch wheels.
5.00 - 15 tires was a factory HD option for my YM240. So that size was probably an option on YM226 too.
Rereading your first post ... 5.00 - 15 means the tire is 5 inches wide. Yanmar's rims for these tires are much narrower, I think 3 inches.
Hey Winston,
Thanks for the parts breakdown.
Do you know anyone who would sell a cheaper wheel than the John Deere Brand?
Hoye has the whole front turf set mounted and shipped for right at $600
/ Front turf tires for YM226 #11
Hey Winston,
No, I don't. You might try contacting a sure nuff tractor tire dealer and asking them that question. I think the 7jax14 is the main identifying number.
/ Front turf tires for YM226 #12
I think Winston and California's suggestions are great. I'll throw out an alternative, mostly so their options look better! I would be surprised if a rear motorcycle tire wouldn't mount up nicely. There are tires available that are rather close in size, and fairly affordable: Shinko SR567 Motorcycle Tire - BikeBandit.com These come in 120/70-15 for $44 apiece. This tire would be just under 22" tall, and not quite 5 inches wide. There are some other options that would vary the width and height, according to sidewall profile and so forth. Those tires are rated for 494 lbs, on a motorcycle, at well over 100 mph. The 5.00-15 tractor tires I first found on eBay are rated to 715 lbs.
I'm not advocating using motorcycle tires on your tractor instead of other things, but if you have a friend, neighbor, or other connection at a bike shop, and money is very tight, it may be worth your while to find out if you can scrounge a pair of tires from there. Especially if foam-filled, I really don't see that not working just fine, to be honest.
Wow 284 INTL.
Thats a great idea.
I have a good friend that works at a local Harley dealership and orders tools and parts for their service dept. Harley Davidson may not be a good source but he may know about cycle tires.
Next thing you know I will be looking at Cessna tires! (just kidding..Aviation tires are priced way out of my league.
Thanks,
Torx
/ Front turf tires for YM226 #14
Pretty much any tire will work, these tractors do not weigh that much. An implement like a hay bailer or something will be far heavier per tire than your tractor will be.
I personally would not drop $600 for a set of front tires and or rears as well. You could buy a whole tractor and swap the rims tires and recoup all or mos of your money, or search CL or call Hoye and see if thye have some used. There is a member here who has swapped out car tires and some sort of rim on his 1700 as well
