Front turf tires for YM226
   / Front turf tires for YM226 #1
Torx
Hernando, MS
Yanmar YM1500 and YM226
Hello Board,
I recently bought a used YM226. It has rear diamond turf tires already installed The tires on the front are Ag 3 ribbed 5.00-15. The specs I have seen say it should have 6-14 Ag ribbed tires.
I am not sure why it has the 5-15 tires in the first place.
Can a turf style tire be purchased for the existing rims?
Or do I have to buy new rims to fit new turf tires.
An online tractor parts supply house has rims and tires for $573 plus shipping and says they will be an inch shorter than my 6-14 stock tires and wheels. Am I going to end up too small for mowing?
I don't have an FEL so steering isn't a problem that I know of. I will be mowing for the most part.
Do I search local tire supply houses and do I just tell them that I have 5'' wide by 15'' diameter rims or does the 5.00-15 on the tire compute to another size altogether?
I hope I'm not asking a silly question. My ym1500 has 8.5/8.00-22 rear tires and I know that the rims are larger than 22''.
Any good places to look)
Thanks,
Torx
   / Front turf tires for YM226 #2
I don't think you will have much luck finding a narrow 15" turf tire,but you could use a car tire.Measure the diameter of the tire and look up 15" tire specs. They are all a little too wide,but will work.Example- a 155/60/R15 is 22.3"diameter by 6.1 wide.
You measure the diameter of a rim from bead seat to bead seat-don't include the lip.
Thanks. I have a questionable left front and hate dropping $600 for new rims and tires.
I'll check the website as there are some really close ones.
And a car tire or small trailer tire might be a good alternative as well.
Thanks'
Torx
   / Front turf tires for YM226 #5
   / Front turf tires for YM226 #6
5.00 - 15 farm implement tire is a reasonable alternative. Broad, smooth tread with grooves. And it will fit the same narrow rim as a 3-rib 5.00 - 15. I see them about $100 each on Ebay.
Is a farm implement tire designed for a farm implement like a hay loader or will they work as tractor tires? I hope this isn't a silly question.
   / Front turf tires for YM226 #8
They should work as well on a 2 wd tractor front as on an implement. You will probably use the brakes more for sharp turns on mushy ground but I wouldn't mow when its that wet anyway. This seems like a simple solution that keeps your existing 15 inch wheels.
5.00 - 15 tires was a factory HD option for my YM240. So that size was probably an option on YM226 too.
Rereading your first post ... 5.00 - 15 means the tire is 5 inches wide. Yanmar's rims for these tires are much narrower, I think 3 inches.
Hey Winston,
Thanks for the parts breakdown.
Do you know anyone who would sell a cheaper wheel than the John Deere Brand?
Hoye has the whole front turf set mounted and shipped for right at $600
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
FAKE (A52472)
FAKE (A52472)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
