fuel filter clean/change for b2920
/ fuel filter clean/change for b2920 #1
Tractorrr
Gold Member
TN
kubota bx 2370-1
I haven't seen a lot about how to change the fuel filter for the B2920. It seems to be one that would require a little more skill since you might have to bleed the fuel line afterwards. The owner's manual also suggests to perform this when the tank is less than 1/2 full. Any advice or tips about how to go about doing the fuel filter change would be appreciated as I don't want to try to do it and then not be able to run the tractor afterwards.
/ fuel filter clean/change for b2920 #2
Easy;
1/2 tank or less (if more then the return line can and will keep the flow of fuel flowing;big mess)
Take off the clear fuel bowl; may be snug.
2 small o-rings don't lose
Remove filter
Clean bowl with a rag (had to scrape gunk with a standard screwdriver)
Re-install filter, bowl, o-rings (fuel will start flowing so be fairly quick) hand tight
Start tractor and run 2000rpm for a few minutes
That's it!
/ fuel filter clean/change for b2920 #3
I did the same as above for the fuel filter on my B3030. I only thing I did differently was I rinsed the filter in kerosene. I also do a little trick reguarding leakage. I put plastic over the fuel opening, then replace the fuel cap. This cuts off air and slows the amount of fuel leaking. Plumbing 101: air moves liquid.
/ fuel filter clean/change for b2920 #4
If your fuel tank would have been 1/2 or less you wouldn't need to worry about the plastic trick.
So you have never had to bleed the fuel line after you change the fuel filter?
/ fuel filter clean/change for b2920 #6
No.
As you re-install the bowl/filter refills while you screw it on bleeding any air out as you finish the install.
/ fuel filter clean/change for b2920 #7
Thats all you need to do is put the box of cling wrap near the fuel cap and it stops the flow? I'll have to remember that one.:laughing:
/ fuel filter clean/change for b2920 #8
Hey guys, I don't know about the 2920, but that 3030 should be the same as mine - I have a 2630. There is a check valve. As soon as the bowl is removed all the way, the flow of fuel is shut off. You simply unscrew the bowl, clean it out, and screw it back on. No leaks at all. I've done it quite a few times.
Ok, this could be easier than I thought then. Thanks
/ fuel filter clean/change for b2920 #10
The operators manual for the B3000 says that the check valve will allow fuel to continue to flow if the fuel tank is more than 1/2 full.
/ fuel filter clean/change for b2920 #11
When I did the filter cleaning on my B3030, I didn't use plastic over the fuel tank opening. With the tank at less than 1/2 full, I still lost over a pint. No problem: with that pint of diesel and the kerosene I used to clean the filter and bowl, I had a nice way to start a fire in my fire pit.
/ fuel filter clean/change for b2920 #12
B2320-- Unscrew filter bowl, remove old filter, clean, install new filter and new o-rings, start and check for leaks. Takes about 3 minutes, tractor starts right up and runs smooth.
Yep, would be nice to have but not the case with the B2920
/ fuel filter clean/change for b2920 #15
Some of the earlier posts did not mention replacing the filter but cleaning it.
I tried that but if you're going to the bother then you might as well put in a new filter.
After my first try and cleaning the filter with kerosene I would get a hesitation at different rpm's but more at low idle. I figured it was the filter.
I put in a new one and had no problems and the tractor is running fine now.
So my advice is change the filter then there is no wondering if you should've or not.
/ fuel filter clean/change for b2920 #16
I agree. Cleaning fuel filters is a waste of time unless we are discussing a metallic screen type element in a primary water separator.
