welding wearing a pacemaker
/ welding wearing a pacemaker #1
professor
Gold Member
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
Have any of you that have pacemakers done any stick welding? I am considering trying to do a little welding wearing a heavy coat and keeping the electrode away from the pacemaker as far as possible. I use a string trimmer and chain saw with no adverse reactions.
/ welding wearing a pacemaker #2
Talk with your MD. You may also want to find out the manufacturer of your pacemaker and contact them as some MD's will just give you a generic no. Do not weld until you do. I have heard you can do limited welding with lower amps, but I have also seen first hand a trip to the ER after trying to TIG.
/ welding wearing a pacemaker #4
I have a pacemaker...and I've worked in companies that did welding.
First, talk to your doctor!!!
It's not just the stinger to be concerned about. The cables produce a magnetic field as well*...that would be the more dangerous issue if your pacemaker is susceptible to magnetic fields.
* I'm sure you're familiar with magnetic particle inspection (better known as Magnaflux). The cables and transformers used in Mag Particle aren't dissimilar to those used in welding... Coiled cables can generate a stronger magnetic field the one cable laid straight out. If you do weld, do NOT drape those cables over your shoulder. If you want to take some of the weight...rig up a bungee overhead that can support the cable weight.
And I reiterate: First, talk to your doctor!!!
/ welding wearing a pacemaker #5
I would not beleive a thing you read on the internet except when someone says talk to your doctor AND the maker of your welder. Both combined would know the real answers.
/ welding wearing a pacemaker #6
A heavy coat? A coat if armor, grounded, may be better protection from the magnetic fields. But don't believe everything you read from the tin-foil hat wearing crowd on the Internet.
/ welding wearing a pacemaker #7
The best protection from magnetic fields is distance...
/ welding wearing a pacemaker #8
I know a mig will screw up a cell phone, I would be highly concerned of the rf effect on my pacemaker.
l
/ welding wearing a pacemaker #9
l
With TIG, the high frequency used for arc stabilization can be a contributing factor.
Now, although I have welded (used to be pretty good with TIG and was certified while in the Navy), my civilian career exposed me to welding. Since the pacemaker was put in in 2008, I still worked in the vicinity of welding equipment but I always stayed a reasonable distances away for the welding work and equipment...same thing with mag particle equipment. I've never suffered any ill effects, but that's just me. Anyone with a pacemaker must (and I repeat myself) talk to their doctor...and even if he gives the go-ahead, I'd suggest ensuring there be another person around to keep an eye out...just in case.
/ welding wearing a pacemaker #10
High frequency used with TIG could cause problems. Never heard of high frequency with MIG but there are magnetic fields when ever DC current is used.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
72" Grapple Attachment (A60462)
72" Grapple...
2016 Komatsu HM400-5 (A60352)
2016 Komatsu...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A60352)
2023 HarbinGer V3...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A60736)
2014 FORREST RIVER...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
