PTO Stump/Tree saw
/ PTO Stump/Tree saw #1
ns_in_tex
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
My latest project was to build a tree saw out of an old discarded brush cutter.
We may later add a hydraulic tree pusher, if we find we need it. Till then, if we have any doubts about how it will fall, we just fall it with a chain saw, then cut the stump off at or below ground level.
It will cut up to 19" in a single pass.
Together with my homemade grapple, I can get some serious work accomplished.
/ PTO Stump/Tree saw #2
Wow, that's quite the ankle bitter you got there.
Now let's see some action videos! :thumbsup:
Well, we have not learned to take video's or post them.
Attached is pic of a 13x17 black jack tree we cut. If you don't already know, black jack is really hard wood. Probably the most hard we have in our area that I know of.
What did you use for teeth. And great job.
We had the saw blade made for us. It is made with 1/2" plate, is cut out for the teeth, then has a 3/4x3-1/2 bar welded in to mount the carbide insert to for cutting. Insert is 3/4x3/4x1/4 rotatable & reversible. All 8 sides can be used.
Attached is pic, this particular one shows one of two weights we added when balancing the blade.
/ PTO Stump/Tree saw #7
looks mean... i bet you lock up pets wife and children in the house before using it.. :)
Nice clean cut and nothing to grind.
You can actually cut below ground level. Of course, you lower the ground level for 4' also.
/ PTO Stump/Tree saw #12
That looks like a nice peace of machinery. What make and model was the discarded brush cutter? Is the main part of the blade mild steel?
The mower was a MG 10 Sidewinder. We had torn up 3 center T Gear boxes by hitting stumps, so got tired of replacing gear boxes.
The 90 degree gear boxes are 75 HP rated, 1 to 1.46 increaser ratio.
Not sure about the grade of steel. We talked to someone else who had built one & he said these people were knowledgeable on the wheels & he was happy with his. We liked his price, so just went with him.
We have probably put 8 to 10 hrs on it so far & have not rotated any tips.
You definitely do not want anything near that could get hit. I did fail to mention, I would sure want a cab or some other form of protection. When cutting through a tree, most chips go to the side, but if you take another pass to lower it one inch or less, chips are hitting the cab heavily.
/ PTO Stump/Tree saw #15
Thanks for the response. I could really use one of those.
/ PTO Stump/Tree saw #16
I reckon you need to beef up the side plating on that. The energy in 4+ foot of 1/2" plate rotating at 540 rpm is mind boggling. Do some sums, but I reckon you'd need at least 3/4 plate around it rather than the 1/4 stuff it looks like. At the moment if that gearbox output shaft let go people in Mexico would be saying "What the F*ck was that!":eek:
It does have lots of momentum. I have cut a 1-1/2" then moved & cut a 3" tree after disengaging the pto. It does slow down very fast (and can even bog the engine down) when it engages the ground, much like a rotary mower. It has two layers of steel between it and the tractor on the front side, and on the rear side it is below all the steel, so I can cut below ground level. Normally we are 1/4 mile away from any living beings.
/ PTO Stump/Tree saw #20
very nice use of being able to multitask an implement can you possibly send me some info on how to change my bush hog this way if its not too much trouble?
