Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #1,441
Hi Leonz, here is a question.
After reading many threads in TBN, I found many customers use different blade for his flail mower, when cut grass, they use grass blade which is Y shape. When cut bush or small trees, they use hammer blade.
From my side, this is un-accpetable, because the rotor shaft balance is fixed once it was produced. This is the vodeo which I took about testing rotor shaft balance: rotor axle electric balance test :) - YouTube a balance block will be welded on after test it.
So what is the real situation when customer use different blade for flail mower? I would like to hear what customers think about this, TBN is a good place to collect these information to help me to improve.
Thank you.
While it is possible to change blades, it is a royal pain in the butt to do so most folks chose a single blade type and make do. There isn't a balance issue so long as the blades of any one type are of uniform weight. When I ordered new replacement blades I checked the weight and in general they are all within five or ten grams of each other as I recall. That won't upset the balance of the rotor.
/ Let's talk flail mowers #1,443
Figured I'd give this thread a bump and let subscribers know I have 3 Kelvar belts and 1 vent extension adapter to fit a Caroni flail mower FS in the want adds. All items are brand new. I'm switching to a different brand of flail mower and I no longer need these spares.
The old saying goes "what goes around comes around". Kinda true in my case with respect to this thread.
I started this epic flail mower thread back in 2008. I had become intrigued with flail mowers and wanted to know more. Well, as the thread started to unfold, I started to talk myself out of the idea. I owned and had owned rotary cutters for years. I knew how to use them and the low maintenance was and is attractive. The more I read in the earlier parts of the thread, the less I wanted a flail mower. Hydraulic oil bubbling out, belts breaking, difficulty in getting them set up, etc, etc, scared me away from the idea. I dropped out of the thread and did not follow it for most of its life.
Fast forward to late 2013. I ran across an old 917 Ford flail for sale. I decided what the heck. I'm not getting any younger and I guess a flail was still on my bucket list. So I bought the 917. I then proceeded to go back and read "Let's talk flail mowers" from beginning to end. Yep all 145 pages.
The mower is at my hunting property which is two hours from my home. It runs because the seller had it hooked up to his tractor and let me have a short test drive. He had recently replaced all the cutting knives. I plan on replacing the belt, checking the bearings and hopefully get it operational without a lot of work. We'll see. I will use it to cut the yard at my hunting cabin, some trails in the woods, and some food plots. It won't get a lot of use, but hopefully it will turn out to be useful. If nothing else, I will be able to make a check mark on my bucket list. As questions arise and I need advice, I'll be back. I know all you flail gurus will be here to help.
Here are a few pics.
/ Let's talk flail mowers #1,445
Keep the bearings greased and it will outlive you. Good luck.
/ Let's talk flail mowers #1,446
H guys, I'm in the market for a new mower. Currently using a JD front deck F932, gas powered(22hp) with 6ft deck. The type of mowing I do is rural, praire grass. Sometimes think with weeds. About 8-20" in height depending on weather, thick in the spring. Fields are rough, lots of gopher mounds, not much for rocks, I've been mowing those fields for 8 years so I've found most of them already. ;)
I'm looking at buying a used JD4400 which has about 30hp at the PTO. I'm trying to decide what type of mower t get. A RC won't give me the finish I want so its out.
I'm not looking for lawn quality but something decent. I have been considering fail but am worried it won't track very well over the uneven terrain.
Also I want to run atleast a 7" cut. It sounds like flails use more power than a finish mower, but less than an RC?
What about speed, given the same HP/tractor, same grass and same width mower, which will cut faster, finish or fail?
What about blade life? Typically with my current mower(which I know isn't meant for rough fields) I get about 8hours of cutting out of a set of blades and I can usually only resharpen them once before they are worn out. Given the extra work involved in changing the knives on a flail I'm hoping that I would get close to a season out of them. How well do they stand up to hitting mole hills and the occasional scalping?
Mowers in my area(Canada Alberta) that I have seen are JD 25a and 390, an older Mott 6ft, Landpride(via the Kubota dealer). Not a lot used, just the Mott and its about an 8hr drive round trip to get it. Thinking of picking it up just to try and then if I like it spend the big $$$$ on a bigger unit.
/ Let's talk flail mowers #1,447
/ Let's talk flail mowers #1,448
If you like your JD front deck, try to find a flail for it.
Here is my front deck 4WD TORO.
And the front flail deck that fits it.
If you don't want to keep the JD, this would do the job. :laughing:
Pictures from an eBay listing.
/ Let's talk flail mowers #1,449
IF you purchase the 25A or 390 flailmower you will
have a mower that you can use for your conditions
and the hardened knives will work well and they are
not costly to replace.
My father ran a John Deere 25A behind a Ford Jubilee with no issues
knocking down 12 foot golden rod recliaming pasture
There are a lot of good new and used flail mowers on www.tractorhouse.com
Mowing speed is strictly dependent on the PTO horsepower and ground speed.
The quality of cut at 2 inches will be perfect as long as the mower is properly
leveled using a bubble level on top of the gear box LEVEL after you have adjusted
the rear roller to a 2 inch cut per the manuals instructions.
You will get more than a season out of the knives on 25A or 390.
My second set of knives is 14 years old by the way
The higher the knive count the better the cut, the finer the clippings
DO not order a unit with the scoop knives!!!
You will be dissapointed with the cut as it will have
a waffle pattern unless you mow at right angles to overlap
Be sure to have a unit with side slicers Y blades.
You can mow in a spiral and save time and money and brakes and have an excellent cut.
A flailmower slices the grass, a rotary cutter or rotary mower tears it!!!
/ Let's talk flail mowers #1,450
Thanks for the tip about the knives, its confirmed what I've been reading about knife selection. I already do mow in spiral pattern to save time. I understand that speed is dependent on a lot of factors but given all things equal, how fast can a flail cut compared to a finish mower? I goal is to speed up my mowing time.
My current mower works well for me but its getting tired, was designed for a golf course not getting beat up in a field. Also now I have an acreage so a tractor with loader and 3pt hitch is appealing. When I do buy a replacement unit I hoping to get something more versatile that will speed up my mowing time over what I have now. Honestly if I didn't buy the acreage I would probably just buy a newer diesel front deck mower like what I have but with more power and 4wd.
I see a wide difference in the number of knives, I'm guessing more is better, finer cut. How does that affect the power requirement? A little or a lot? Is a JD440(28pto) upto powering a 7ft flail in thick grass?
/ Let's talk flail mowers #1,451
I haven't seen much discussion of Sicma flail mowers here. It appears that they're carried by Everything attachments under a Phoenix branding and by Equipment Barn under Sicma and by Gearmore under their branding. Oddly, the Gearmore version of the SLE-120 is listed as being 60 pounds lighter than the other two.
Any thoughts on their quality and performance compared to the Caroni that everyone seems to buy?
/ Let's talk flail mowers #1,452
The Sicma brand has been around for along time and
you will not go wrong with it.
Ken Sweet who is sponsor still handles them I believe.
You are not that far from the folks at Vrisimo mowers
either so thats something to think about as well as they are built in California.
/ Let's talk flail mowers #1,453
The Vrisimo mowers are a little pricy but I like the fact that they are USA made along with a country wide dealer network.
/ Let's talk flail mowers #1,454
I've just finished reading all 146 pages of this epic and interesting thread. Based on the information I think a flail mower is exactly the solution to my mowing requirements. I own approximately 30 acres of mostly open ground. Some of that land (about 9 acres) is in the Conservation Reserve Program which means mowing twice a year at most. There is some quite tall bluestem and other native grasses on that land. Some of the Big Bluestem is taller than my tractor. Approximately 5 acres was finished mowed by the previous owner using a riding lawnmower. About 2 acres are woods and will not be mowed obviously. Finally, there are two fairly large ponds that together use up about 3 acres. The remainder is in well maintained pasture that was mowed fairly regularly using an old rotary cutter. The finish mowed area has quite a few widely spaced trees, some of which will be a bit difficult to get under with the tractor. There is really no heavy brush to speak of. There are, however, some slopes. Only the two pond dams have any slope of significance, but the previous owner mowed those with his rotary cutter and a Kubota L series tractor so I don't expect there should be any issues with using the flail and my tractor on those slopes either.
Judging by what I've read on this thread, I think my needs would be well served by one of the Caroni TM1900BSC units. A golf course appearance is not something that is important to me. Quite frankly, the lawn doesn't have that appearance now with the previous owner's John Deere 500 series lawn tractor. My tractor has 42 horsepower and about 33 PTO horsepower. It is equipped with the three range hydrostatic transmission. Cost is a consideration, but so is quality. The Caroni seems to be a good balance of cost and quality-bang for the buck so to speak. What says Flail Nation? Any and all input would be appreciated-including suggestions of other makes and/or models.
/ Let's talk flail mowers #1,455
I have same size tractor and also mow field and conservation land. My Caroni TM1900 has done well over the past six season. My only issues is that being New England we grow rocks and I knock off a set of knives and clevis (about $20) a couple or few times a year. You've read about the need for a spare set of 3 B43 belts and diligent use of a grease gun. That's about all that's needed. The trade off compared to a bush hog is higher maintenance for better cut and less risk of throwing objects.
/ Let's talk flail mowers #1,456
Thanks for the information IslandTractor. I'm in southern Illinois and we have rocks here too. This is hilly and largely wooded country in this part of Illinois-nothing like the open prairies and deep topsoil in the central and northern part of the state, but the soil in my location is relatively deep and the rock close to the surface was long ago removed if it ever existed. The rock that is encountered in this area is mostly sandstone, which is relatively soft. In the woods on my property there iare sandstone outcroppings, but that area is a draw that contains a little stream that helps drain the hilltop on which the majority of my property is located. In other words, erosion has worked its way down through the soil to the underlying sandstone in that area. On the flat top of the hill where my property is mostly located the soil is relatively deep and the surface stones were long ago removed by previous generations of property owners.
I've never seen a flail mower used in this part of the country except by highway departments. Most folks use rotary cutters. But I like the idea of having one machine instead of two (a bush hog and finish mower) and like the relative compactness of the flail which I believe will make the tractor that much easier to maneuver. I may still use a push mower in the area immediately adjacent to the house just to avoid having rutting issues from the tractor close to the house, but I think for the rest of the property a flail would be great.
/ Let's talk flail mowers #1,457
I do that combo thing too. I have a small battery powered mower that does the lawn 20-30 feet from the house and the flail does most everything else. If I remember, I will use the bush hog for the first mowing in the spring to allow me to see where the new crop of rocks are but mostly I just use the flail for mowing.
/ Let's talk flail mowers #1,458
I'm wondering about whether a used Ford 918 3pt 8ft flail is too big for my "mule".
HP PTO = 32.5
Rear lift (at 24"): 2,200 lbs
Thanks
/ Let's talk flail mowers #1,459
HP PTO = 32.5
Thanks
How fast do you want to mow? With 32hp you could run the mower but in thick or moist grass you'd bog down pretty quickly.
/ Let's talk flail mowers #1,460
So i am in the midst of getting a new JD 4120 or 4720. I am seriously looking at the JD 25a or 390. My concern is my yard is uneven and a has a couple steep hills. I have some rougher wooded area i want to make and trails and use the flail to maintain that. I looked though this thread a bit but couldnt confirm. I need to decide first of the week to get my order in so i can get the new tractor in soon. I appriciate the help. I really like the idea of how these work just not sure it would apply to my mowing.
Josh
