Used Kubota B7800
/ Used Kubota B7800 #1
mitchash
Gold Member
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
I found a used B7800HSD with loader, backhoe, cab, and snowblower. Just over 1000 hrs. looks in decent shape, has turf tires in the rear and industrial tires in the front. They are asking $17,000. for the whole package. Are there any issues with this model that I should know about? Is that a fair price for it? Will it run my 5' brush hog? What should I look for on the tractor?
/ Used Kubota B7800 #2
I have used a B7800 HST with a BH.Capable machine for its size.Would need a little more detail on the make of the back-hoe,cab,loader and blower.It will run a 5ft.bush-hog as long as its not too heavy going.How is the general condition?Paint faded,leaks,dings ect.
/ Used Kubota B7800
The backhoe is Kubota with quick frame mount and the loader is Kubota. The cab is aftermarket I think it's Curtis. It has a few dings and dents but not bad.
/ Used Kubota B7800 #5
I would guess that tractor with the FEL&BH sold for about $17,000 new.So you are gaining a snow-blower($2000+-) and a Curtis Cab($1500+-) with 1,000hrs. I would offer $15,000.My only concern is the two different styles of tires.
/ Used Kubota B7800
It has a heated Curtis cab and a BH75 backhoe. I can't find any specs on the loader and backhoe. How much will the loader will lift?
/ Used Kubota B7800 #7
If it has a Kubota loader;the number(I.E.513) x 2 is roughly the capacity in pounds.513x2=1016lbs.
/ Used Kubota B7800 #8
I did not know that!!!! Is that true for all models??
/ Used Kubota B7800 #9
think it's actually 2.2 times the first 2 numbers. the third being the revision. B7800 should have a 402 loader so 880#. I would guess more like 23000 new. I have a b2910 with loader and trencher that cost 24000. Substitute backhoe for trencher and b7800 was a little less than 2910.
/ Used Kubota B7800 #10
Think 2.2 lbs as in a Kilogram weighs 2.2 lbs. Remember it is approximate. but yes pretty close.
/ Used Kubota B7800
What are the specs on the BH75 backhoe?
/ Used Kubota B7800 #12
Model Overview & Specs
Chassis
Dig Depth 2 ft. flat bottom: 91.0 in. (2311 mm); 8 ft. flat bottom: 69.3 in. (1761 mm)
Reach 42.0 in. (1067 mm)
Bucket Rotation 182 deg.
Swing Arc 180 deg.
4-point mount quick-attach convenience combined with rigid mount sturdiness
2-lever control provides smooth, easy operation
Powered by the tractor hydraulics
Not compatible with B3030 HSDC cab model tractor
Compatible with front loaders and mid-mount mowers (performance matched system)
All hoses are routed through backhoe arm
Sub-frame doesn't interfere with the mid-mount mower linkage, there is no need to remove the sub frame
Specifications
Application: B2630HSD, B3030HSD, L2800, L3400
Transport height: 80.4 in. (2042 mm)
Stabilizer spread transport: 51.8 in. (1315 mm)
Ground clearance: 12.9 in. (327 mm)
Overall width: 54.9 in. (1394 mm)
Maximum digging depth: 92.2 in. (2341 mm)
Digging depth, 2 ft. flat bottom: 91.0 in. (2311 mm)
Digging depth, 8 ft. flat bottom: 69.3 in. (1761 mm)
Operating height, fully raised:: 120.1 in. (3050 mm)
Loading height: 81.8 in. (2077 mm)
Loading reach: 42.0 in. (1067 mm)
Reach from swing pivot: 120.5 in. (3060 mm)
Swing pivot to rear axle center line: 38.4 in. (976 mm)
Bucket rotation: 182 degrees
Stabilizer spread operating: 67.6 in. (1717 mm)
Angle of departure per SAE J 1234: 18 degrees
Leveling angle: 10.2 degrees
Swing arc: 180 degrees
Digging force using bucket cylinder: 3339 lbs. (1514 kg)
Digging force using dipperstick cylinder: 2097 lbs. (951 kg)
