Rear wheel width setting vs. Bucket Width
/ Rear wheel width setting vs. Bucket Width #1
jrdepew
Johns Island, SC
Ford 1920, JD LT180
Hello,
I have a question about how wide the rear tread width should be set in relation to bucket width. I did a lot of searching on this, but it seems that no one posts results, just the question! I have a Ford 1920 with R1's, which allow a ton of different tread width settings. They are out to the maximum right now, and the outside of the thread on both tires has a span of a few inches under 7'. This is great for stability and gives me a sense of security as I am new tractor operator. The previous owner set it up this way. For some reason, the bucket my tractor has is a 60" HD bucket. The 7108 loader manual states that my tractor should have had a 68", but it doesn't. Part number and a measurement point to a 60".
So, my tires are wider than my bucket by about 1 foot on each side, two foot total overhang. Nearly the whole tread width is outside the bucket edges at that point.
If I could find a 7' bucket and adapt it when I do my SSQA conversion, would it be way too much for this tractor? The rear tires a filled currently and I plan on making a ballast box come spring, but that is 16" wider than the recommended bucket (68") for this tractor.
7108 Loader Specs on 1920:
Lift Capacity to full height - 1100lbs
Full height - 101"
Breakout Force - 2790lbs
1920 specs:
Weight without FEL: 3069lbs
Rear Tires: 14.9-24 R1
Front Tires: 7.5 L-15 rib tread
Weight with FEL and filled tires: ?? I'm guessing over 4000 lbs
A 7' bucket has a struck capacity of somewhere in the 16 cubic foot range. Assuming crushed gravel @ 125lbs/cf and a full load (something I struggle to ever do), that is 2000lbs, which is way beyond my lift to full height (and I would never lift something that heavy very high. I don't plan on loading trucks or anything like that. Just spreading gravel on my driveway). It is within my breakout force, even when the extra bucket weight is added, but narrowly.
Another option is to find a 72" bucket, and narrow my stance a little so I am as close to 72" outside width as possible. Struck capacity of about 13cf, so a full load would be 1625 lbs. I am more comfortable with that number, but I wish I didn't have to narrow my stance at all!
Any opinions or comments on this? I imagine a 7' bucket has a lot more chance to rack the FEL if I hit something uneven as well. A 72" bucket is only 2 inches on either side wider than the suggested bucket for the 7108 loader on a 1920, so that doesn't seem to bad as far as chance to rack the FEL.
Anyone know what size buckets similar tractors can handle?
Thanks,
Joe
/ Rear wheel width setting vs. Bucket Width #2
If you aren't digging holes with the FEL, the wider tread wont bother you any but if trying to dig a trench you wont be able to do that very well. Do whatever you need to do to get the outside tread not more than the outside of the bucket, be it a larger bucket (not a 7 foot as that is way too large)or narrowing of the tread a bit. I don't think your tractor will handle a 7 foot bucket. It could hold much more dirt than you could safely lift and it would be hard to load a 7 foot bucket in all but the loosest sand.
As far as racking the FEL, it can happen with a small bucket easily if hitting an immovable object on one corner and lifting the FEL, just more damage could be done with a much wider bucket.
Remember that a larger bucket is going to weigh more so your Tare hauling capacity is going to go down.
/ Rear wheel width setting vs. Bucket Width #3
Joe,
I have to ask, what difference does it make if the tractor is wider? What are you moving, loading that having a wider bucket would make all that much difference?
/ Rear wheel width setting vs. Bucket Width #4
I had a IH574RC tractor for more than 20 years with a 65 inch bucket and a 7 foot tread width. It worked great and I would never have thought to worry about the bucket width vs the tread width. I didn't plow snow with it or dig ditches. Just moved wood and lots of mushroom soil.
/ Rear wheel width setting vs. Bucket Width #5
I don't think your tractor/FEL will like a 84" bucket. My Brother has a Kubota L3240 with FEL. We sometimes have my 84" bucket on his tractor. It won't begin to handle it. Hard to get a bucket full and if you do, you can't lift it.
I agree that your 60" bucket is a bit small.
On my M9540 I run a 84" bucket. My rear tires are outside my bucket 6" on each side. I get along with it fine that way.
I'm not in favor of you narrowing your tires to be inside your 60" bucket. I think your tractor will be very unstable setup that way!!! Just my opinion!!!
Joe,
For right now, there isn't much difference. I run over my snow piles with my back tires when doing the driveway, but that isn't a big deal. I would like to get a rear blade for this job anyway. Or, I could fabricate some wings for the loader bucket to get wider in the snow.
In the future, digging a ditch or leveling with the FEL is supposed to be easier if the tires fall within the bucket width, and that makes sense. No immediate need really, but I always keep my eyes open while going down the road and on CL looking for something I could use.
Thanks for all the info guys. I will probably keep my eyes open for a 68-72" bucket, or consider widening mine in the future if I find I need it.
I am also keeping my eyes open for a rear blade, but not sure how large to get. Any suggestions there?
Thanks again,
Joe
/ Rear wheel width setting vs. Bucket Width #8
Does your manual spec a maximum front tread for loader use? I have much bigger tractor and mine specs 71" (center to center) which is where I set mine. I then set the rears to the same overall width as the fronts, so if the front tires fit thru an opening the rears will too. So am about 84" overall width and have a 73" bucket.
As long as you remember; "that just because the bucket fits thru an opening it does not mean the rest of the tractor will" you will be OK.
I agree with the others an 84" bucket would be too big and of little use on your tractor.
If you do narrow your fronts be sure to check for tire contact to the tractor at full lock to lock and articulating the front axle. You may have to adjust your steering stops.
/ Rear wheel width setting vs. Bucket Width #9
Do you have a box blade that will cover your rear tires or a back blade that could be offset enough to cover one tread?
I'm thinking of road building work or digging a trench, where most of the bulk excavation can be done with the FEL.
Then the edges of the excavation can be cleaned up with the rear implement.
The ballast on the back would help your FEL performance & traction, too.
/ Rear wheel width setting vs. Bucket Width #10
The previous owner of my tractor had wheels set to widest and it was a pain mowing up against objects like a fence. Further more, widening treads is intended for crop row spacing, not stability. Id set the tires in to line up with front tires. Keep your rops up and load the back tires for stability.
/ Rear wheel width setting vs. Bucket Width #11
Really? I set mine at maximum width for hillside stability, and many threads I've seen here seem to recommend doing exactly that.
Terry
/ Rear wheel width setting vs. Bucket Width #12
Terry
I set mine out further for stability too just not to the maximum. I was told that the maximum setting was not intended for maximum stability. Maybe an ole farmer will chime in.
I don't have a box blade or back blade yet. Still looking for one. Do you think a 7' back blade would be too much for a Ford 1920? This would cover both tracks, unless heavily angled. Would I be better off looking for a 6' blade that can be offset?
Something like this maybe: Everything Attachments 7ft 6 Way Deluxe Value Scrape Blade for Compact Tractors with 25-50 HP V2.0 I was surprised to see this blade only weighs around 325lbs though. The 7' version weights in a 345lbs.
Thanks,
Joe
/ Rear wheel width setting vs. Bucket Width #14
I grew up on a farm does that count??? The further out you set your wheels, the more stability you create. It's simple mathematics.
/ Rear wheel width setting vs. Bucket Width #15
A Ford 1920 will handle a 7ft grader blade nicely. You could try different wheel widths until you find a setting you like.
/ Rear wheel width setting vs. Bucket Width #16
Sure it counts but when you get too wide in the rear you start to create a tricycle. Your front axle is free floating as im sure you are aware. There is a false sense of security by going to far, or so says my simple math book.
/ Rear wheel width setting vs. Bucket Width #17
My rear tires are set at max width (80") and my bucket is 72". I do have Rimguard in the rears (755#/tire) and always have some implement on the 3-point. I have never experienced any instability nor have I ever had any problems relating to bucket vs rear tire widths. Oh, BTW, my front tires are set as wide as possible also.
/ Rear wheel width setting vs. Bucket Width #18
You have a tricycle no matter what the width of the rear wheels - making them wider doesn't make that any more true. But the wider the wheels of the tricycle the more stable - simple physics. The wider the downhill wheel the steeper the hill has to be before the center of gravity lies outside the vertical plane through the point where that wheel touches the ground. And, the further up the hill the uphill wheel is, hopefully loaded, to better resist overturning.
Terry
/ Rear wheel width setting vs. Bucket Width #19
Sorry but you can not get too wide. And that goes for both front and rear. The point of no return comes when the center of gravity of the tractor and load in the bucket goes over the line of rotation which is the line from the outside edge of the rear tire and the outside edge of the front tire on the low side. The front axle will get to is stop on the swivel before this point so this often erroneously made claim does not matter at the point of no return.
Being set too wide may be harder on axles and wheel bearings then a narrower setting but that is a different issue from role over safety margins.
/ Rear wheel width setting vs. Bucket Width #20
I agree with you on most of this, but wonder about this last point. When you are on a significant side hill I'd think that once the uphill rear comes off the ground enough for the front axle to hit the stop you have likely already lost it. Does anyone know of any actual facts on this?
Terry
Kubota RTVX1100C (A64127)
Kubota RTVX1100C...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
213089 (A64276)
213089 (A64276)
2012 International 4300 Reefer Truck (A63689)
2012 International...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
