Tractor Sizing Why are Kioti CK's so **** heavy?
   / Why are Kioti CK's so **** heavy? #21
Are they really heavier than JD's? What's the biggest hydrostatic drive CUT that Kioti makes? The DK50 SE HST? Isn't it the same weight (or even a little less) than a JD 4x20?
   / Why are Kioti CK's so **** heavy? #22
The DK50Se is Weight: 3902 to 4354 pounds and the 4x20 series is 3850lbs.
   / Why are Kioti CK's so **** heavy? #23
I guess that's my point. So your talking 48 pounds at best? Anyway, the Nebraska test lab shows the unballasted operating wieght of the 4x20 (open station) at 4025 pounds. Even so, we are talking very little difference in weight. I was just wondering where the notion comes from that the Kioti is much heavier than JD's....I guess it's always puzzled me.
   / Why are Kioti CK's so **** heavy? #24
Well Puzzle away. I'm not talking anything, I just answered your question.
   / Why are Kioti CK's so **** heavy? #25
Thank You, I do appreciate it. I was not trying to be confrontational; just wondering where some of these forum myths come from.
   / Why are Kioti CK's so **** heavy? #26
Well if you use the high end its 306lbs difference.
   / Why are Kioti CK's so **** heavy? #29
Well the Dk35se is just a DK 40 with one cylinder chopped off and slightly smaller wheels. It outweighs most other 35 horse tractors except maybe mahindra and The R series LS. It is over 1000 more than the L3400 I traded in.
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
GRAIN AUGER (A52708)
7ft Double Legs Lifting Chain Sling (A57454)
7ft Double Legs...
