Tractor Sizing Why are Kioti CK's so **** heavy?
   / Why are Kioti CK's so **** heavy? #11
FWIW, Some manufacturers have been known to make thicker/heavier castings to coverup poor castings. Ken Sweet
And, Kubota dealers have been posting crap like that for years. Korean steel making is every bit as good as the Japanese for items like engine and transmission castings. Compare a Hyundai to a Toyota. No significant difference these days.
Kubota makes a lighter tractor because their main market is lawn cutting. Kioti and Mahindra just make small versions of traditionally built utility tractors. No difference in quality.
   / Why are Kioti CK's so **** heavy? #12
One is a Tractor and one is a Lawn Mower. Easy Peassey
   / Why are Kioti CK's so **** heavy? #13
Well I can see the downward spiral of this thread, Kioti a real tractor and Kubota a lawn mower; seems to always be the case.
   / Why are Kioti CK's so **** heavy? #14
Just kidding, Keep your suspenders on.
   / Why are Kioti CK's so **** heavy? #15
Nah, if I was taking care of an estate or golf course the Kubota has clear advantages. If you are doing ground engaging work or loader work where weight and heavier axles are an advantage then the Kioti has clear advantages. That doesn't mean either cannot do either task just that each is best at only one.
   / Why are Kioti CK's so **** heavy? #16
One of the distinct differences on Kiotis (from say deere or Kubota) is the axles. Kiotis are markedly larger. This lets them spec higher capacity loaders. I get free horse manure from a neighbor that has a Kubota 4420. Real nice running tractor. But, the light axle continues to plague him. He has to rebuild it every year. He uses it mostly for loader work and has huge mounds of manure he moves with an oversize muck bucket. It has R1's which look to me to put more pressure on the axle too.
I bought a Kioti in part because of its weight. For ground engagement, there is not substitute. If mowing were part of the equation, I probably would have gone Kubota or deere. I have a CK25 with loaded R4s. With backhoe it's about 6200 lbs, without about 5100 lbs. I take it on my yard all the time, but only when dry. Continued travel over the same path can lead to compaction because it is a heavy beast. But, if loader, grading, backhoe work are the primary uses, I wouldn't have it any other way. Loaded tires are a must; it lets you do loader work without a rear implement, thereby giving you a smaller more maneuverable platform and keeps you planted when backhoeing. I still use a rear implement at times, just for the added safety when working on uneven ground.
   / Why are Kioti CK's so **** heavy? #17
To look at tractors from small to large much has been done in changes from the way they were built fifty years ago compared to today. When a dealer sets up a tractor to recommend to a customer they should look at what they will do with it first. Many of the uses that an owner will have for a tractor do not require a great amount of weight but they do need horsepower. Weight has long been known to cause ground compaction which hinders growth of roots and plant life and continued excess compaction will kill the plants. It also takes extra fuel to move weight that isn't always being used.
Some will talk of the merits of cast aluminum vs cast steel and there are variations of both and they both have there strong points. There are other things that come into play with tractor design with the different metals, cast steel is normally used as a structural piece where with aluminum there is normally a fabricated steel frame which is far stronger as it is more dense then the cast steel although the newer design nodular cast iron is a more dense form of cast iron. For the most part the older designs of tractors still use the cast iron housing of years ago as a way of economically building machines.
Many of the farm tractors of newer design from the last twenty years are using aluminum and the steel frames as a superior way of getting the weight to where it is needed for performance as well as for strength. When tractors are put out for hours a day and you can watch the fuel gauge doing the same job they find that lighter is better on the pocket book. Farmers have found great savings in having tractors set up to do a job vs trying one set-up for all.
To use a tractor with a primary purpose of loader work many farmers go to machines that are built for the daily rigors of that type of work. Kubota does offer factory built TLB units that have high output hydraulics compared to normal compacts and also have additional weight built into the frames as well as larger cylinders that need the larger flow from the bigger pumps so work can be done with out delay of waiting for the tractor attachments to get into position to be further activated.
Kubota's aren't built carrying extra weight and are built for overall performance which means capacity as well speed and durability. That is why many contractors don't look at many of the other makes as much as they might get by with a different make, time is money to them and they normally buy machines that are made for the job.
For many the kioti type designs are sufficient for the owners to get the tasks at hand done within the time and costs of ownership vs the newer designs of tractors.
This purchase is about you and what you need and how you want to get your work done and any brand can get your job done. How you want to get it done and how much you want to spend is what it is all about. Otherwise you'd be asking about used tractors!
   / Why are Kioti CK's so **** heavy? #18
The whole Kubotas are built for speed and performance, and don't carry extra weight, vs. Kioti or others, in my estimation is a crock. Different strokes, different folks. One needs to add 1000# of ballast to most tractors to enable them to do effective FEL work. Ground compaction is a factor if one is doing crops but the wheel spacing takes care of that mostly. Bota makes TLBs of the commercial type because they are in that market. It is a different market, for a different buyer/user than utility tractors/scuts. 50 years ago and even 20 years ago is largely irrelevant to what is happening today with tractors.
Fuel delivery and processing, (Tier 4 compliance) is what is cutting edge today, and those who can't/don't comply will be gone.
   / Why are Kioti CK's so **** heavy? #19
That was well said.
   / Why are Kioti CK's so **** heavy? #20
That was well said.
I agree. I don't always agree with Art but I think that was a fair summary.
What he didn't directly address was the simple conclusion that among CUTs, the light weight machines (Kubota, JD) are going to generally be better at mowing finished lawns because of their lighter weight. The corollary however is that they 1) are more dependent on adding ballast for FEL and ground engaging operation and 2) light weight axles limit the size of the loaders for a given weight class tractor. The heavier CUT tractors generally have "stronger" loaders at any given horsepower range. Only an issue if one major use of the tractor will be pushing the limit with the loader as for example in land clearing. Otherwise not a big deal.
Tank Only (A59076)
Tank Only (A59076)
John Deere 6110M (A53317)
John Deere 6110M...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
