new starter
/ new starter #1
smilindave
Dayton, Pa
Power Trac 425
Well after nursing my pt425 for close to 2 years the starter finally died. Put a new one on today and wow! What a difference it made. It was about 30 degrees and I did the replacement outside. I was sure I would have trouble getting it started with it being so cold out, but not so. The starter turned the motor over like it was 70 degrees. Why did I wait so long?!
/ new starter #2
That's great news!
Such is human nature, i jiggled and cajoled a bad ignition switch for months before it finally failed completely, then i had to change it. :laughing:
/ new starter #3
That matches my experience with my 1445. The new starter felt like it was 2x more powerful than the original, but that's probably why it failed...
Congratulations on the upgrade!
All the best,
Peter
/ new starter #5
Changing a starter on the Deutz engine is very straightforward.
  1. Disconnect the battery
  2. Disconnect the starter
  3. Unbolt the PT starter solenoid (not the one on the starter)
  4. Remove two bolts on the starter
  5. Slide the old starter out
  6. Slide the new starter in
  7. Bolt starter down
  8. Fasten the starter solenoid on
  9. Rewire the new starter
  10. Reconnect the battery
  11. Start the engine.
There is lots of room to work in. Just don't do it right after using the tractor- there is only about two inches of clearance to the muffler.
All the best,
Peter
/ new starter #7
Peter,
I thought about changing mine out. However, there is no room in the tub to get my hands near the starter. I think when my starter finally goes I will have to pull the motor out of the tub to get to it.
/ new starter #8
Believe me, I know how that goes. I keep finding bolts that are inaccessible with my fingers and the wrenches that I own...
Servicing the Deutz is a gift compared to many engines that I have worked on.
All the best,
Peter
That sounds like a pretty straight forward process. The smaller ones aren't bad, except not have any room to do most of what you said. :laughing:
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
Lot 602 (A62613)
Lot 602 (A62613)
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2015 Volvo L110H Articulated Wheel Loader (A64553)
2015 Volvo L110H...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
JOHNSON 1R POTATO HARVESTER (A64278)
JOHNSON 1R POTATO...
