316 hydro dif unlock
/ 316 hydro dif unlock #1
henrysMFGC2310TBL
Carleton Place, ON
JD D140
316 snow blower.jpg316 JD tractor.jpgI was given a 90 316 today and we could not find where to unlock the diff to push it so we put it on dollys and then dragged it onto the trailer. Would someone please tell me where the lever(?) is, not visual like my other JD's are, thanks, Henry.
/ 316 hydro dif unlock #2
Did you look inside the RH rear wheelwell? Should be a lever there.
Ken
/ 316 hydro dif unlock #4
The 316 I believe is the same as the300 and the 300 has a knob right in front of the seat that u can turn and it will release the hydrostatic so u can push the tractor
/ 316 hydro dif unlock #5
No,the 316 has a lever underneath the seat pan on the right frame rail.
Greg
/ 316 hydro dif unlock #6
I wasn't sure but now that I think about it it is under the fender lol sorry about that
/ 316 hydro dif unlock #7
Kinda like the 318 ???
/ 316 hydro dif unlock #9
There were two 316's , totally different animals . 1978 with a Kohler single and a later model with Onan twin . Yours is the later model .
Went out yesterday after the snow stopped and uncovered the tractor and saw the lever on the right side just in front of the wheel. Here is a pic, thanks to all for your help.
/ 316 hydro dif unlock #11
Henry,one thing to be aware of. If that tractor has been sitting for quite some time,there is a good chance the "buttons" on top of the two relief valves that the lever pushs on may be frozen. Just because you move the lever won't necessarily mean the relief valves are working.
Greg
Greg, thanks for the info. We pulled the 316 with our 185 and the hydraulics were unlocked. Parked outside and covered for the winter.
Sakai SW354 (A60462)
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59910)
2006 STERLING...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
Rogator RG1100 (A63118)
Rogator RG1100...
2023 Stearling Trailer (A60352)
2023 Stearling...
