Stihl MS 290 starting issues
/ Stihl MS 290 starting issues #1
ratzoe
Maryland
John Deere
Good morning, I have read most threads about starting problems but still have having problems getting my chainsaw to start.
Tried to start it 2 weeks ago, would sputter(fired) like it wanted to start but would immediately cut off. Read a bit here and saw that the fuel line could be bad, so pulled it apart and replaced the fuel line and air cleaner (the fuel line was cracked). After cleaning it up and putting it all back together, I am getting no signs of starting. Plug was replaced last summer so I don't think thats an issue. Any ideas?? Thanks, any help or pointing to another thread would be appreciated.
/ Stihl MS 290 starting issues #2
Does it pull like it has good compression? Sometimes mine pulls like it has no compression and won't crank. I think it has a sticky ring.
/ Stihl MS 290 starting issues #3
Fresh mix?
Might need a carb clean, or kit?
/ Stihl MS 290 starting issues #4
One thing I learned about 2 cycle engines that you must clean the muffler out every so often.
/ Stihl MS 290 starting issues #5
Could be flooded.
Feels the same as before, good compression
Fresh mix?
You could be right that the carb needs cleaning or a kit.The thing is that it was firing prior to changing the fuel line and air cleaner..And yes, it was a fresh gas mixture.
Appreciate the replies, guys, thank you
Have read about priming, a little gas mixute down the plug hole and retry??
/ Stihl MS 290 starting issues #9
Assuming you didn't foobar something while replacing the fuel line and after they sputtered you backed off the choke, I'd suspect a gummed up carb, possibly due to ethanol in gas.
I've had gummed up carbs that I fixed by a double dose of carb cleaner, time and patience.
Due to a back injury and subsequent surgery I let two 660's set with ethanol fuel in them for months. Neither would fire after I recovered. I drained ALL the fuel, put in fresh canned mix w/ a double dose of SeaFoam, then cranked them a dozen times. Let sit for a day, repeat the attempt to crank. It took a couple of weeks and I wouldn't do it every day, but eventually they fired.
Since then I only used canned ethanol free or bought ethanol free gas and with trial and error they seem to last months with fuel. I never know when I'm going to have to use one, and they are at different locations, but even after 2 months of non-use they sputter up after about 5 pulls at the most. Then I back off the choke a notch and they run in about three more pulls.
I've similar experiences with my other 4 saws, my 2 Stihl weedeaters and my BR400 backpack blower.
Other carb cleaners or home brew mixes may work. I rely on SeaFoam.
I was wondering along those lines since I have a generator that went through probs with ethanol and Seafoam clearing that up. This saw is 9 yrs old and this is the first time I have ever had a problem with it, but I think you are probably right about a gummed up carb.
/ Stihl MS 290 starting issues #11
Did you happen to check the impulse line while you were replacing the fuel line and fuel filter.
No, not even sure where or what the impulse line is. Took the cover off, removed the air cleaner and carb, pulled old fuel line/filter, replaced with new, put carb back on, new air cleaner and cover. Did not disturb or touch anything else, it was fairly straight forward with nothing in the way.
/ Stihl MS 290 starting issues #13
You removed and replaced the carb. Did you replace the gasket between the carb and engine?
When, if ever, have you replaced the in tank fuel filter. Is the in tank fuel line and filter able to get access to gas mix at the bottom of the tank?
Replaced fuel line, filter and air cleaner. Gasket on carb was fine as far as I could see. Also, now I know what the impluse line is, didn't know it was called that, it was good, no cracks or breaks.
/ Stihl MS 290 starting issues #15
You may now have a leak between the carb and engine; even though the gasket 'looked' good it may not be sealing. I'd remove it again and coat the gasket with a thin coat of vaseline or grease, and then put it back on and see what happens. Any air leaking past the gasket will keep it from starting.
Thanks, I'll give it a shot.
ASV Engine & Parts (A66285)
ASV Engine & Parts...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
