Front-End Loader Tooth bar options and. Advice?
/ Tooth bar options and. Advice? #1
clovergamecock
Gold Member
Clover SC
Kubota L2800 4WD FEL
I have a 2006 Kubota 4x4 L2800 with FEL. I am always doing projects on my property that require moving dirt. The straight edge does the job but not great. What are my options on adding a tooth bar. I am looking for the most economical piece or even a diy option, of course reviews and advice is greatly appreciated.
Thanks
Wade
/ Tooth bar options and. Advice? #2
I had good results with a WR Long Flat Tooth Bar in rocky mounds of excavated soil. Even on a tractor smaller than yours, viz., the BX2660, I was pleased with the results. Then later, when I moved to a B2620, I bought the Piranha Tooth Bar that has worked great in turf and bushy soil. The bars bolt on/off easily as needed....e.g. for snow, scooping manure etc. Cheers, Mike
/ Tooth bar options and. Advice? #3
/ Tooth bar options and. Advice? #4
I put a Piranha Tooth Bar on my LA504 on a B3200. It makes a world of difference on brush and leveling dirt. I can run it into brush and then backdrag it into a pile. Level the loader and help the pile into the bucket with a pitchfork and off to the burnpile. Best tool i've ever bought.
/ Tooth bar options and. Advice? #5
X2
We have had a very similar experience with our use of the BXpanded PTB.
After all, digging and raking are what the PTB were specifically made for. Go to BXpanded.com and check it our. Harry was great to work with and very helpful in answering my (many) questions.
He can make them in a size to fit whatever you need, and can even leave a gap in the teeth (if desired) to allow use of bucket forks- we also recommend those for removing piles of brush to you burn pile, or wherever you need them to go.
Check out the Yankee Warehouse for their chain-on forks, they offer a pretty unbeatable combination of low price and high value. We use them constantly.
Thomas
/ Tooth bar options and. Advice? #6
I have one on an L3400, definitely a worthwhile addition. Makes a big difference in digging capability.
I got mine a few years ago from Markham, when they were still Markham. Looked at some of the threads linked above, prices seem a good bit higher now.
Thanks for the info. I am waiting on a reply now from BXpanded.com.
Wade
/ Tooth bar options and. Advice? #9
X2
Thomas
X3 on the Piranha, besides getting a good bite in dirt, it works great for pushing brush into a pile and clearing out small diameter trees and brush.
Just be careful, the teeth are sharp!
/ Tooth bar options and. Advice? #10
Wow, that looks nice. I have not seen as good a picture as that before. Do the teeth rust? My bucket sits in the weather.
/ Tooth bar options and. Advice? #11
. . . Just be careful, the teeth are sharp! . . . .
I was doing some maintenance on my BX23 today and had the bucket up in the air. I wasn't paying attention and walked right into it and banged my forehead. :mad: Glad I haven't ordered a PTB yet. :D
/ Tooth bar options and. Advice? #12
View attachment 346313I put a tooth bar on mine soon after I got the tractor. Its great help for digging and as a "back-drag" for smoothing. Mine is just a simple tooth bar(Rankin) not one of those exotic, sharp shark tooth ones. I "bump & bleed" often enough with what I've got - don't need a sharpened one.
/ Tooth bar options and. Advice? #13
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=346313"/>I put a tooth bar on mine soon after I got the tractor. Its great help for digging and as a "back-drag" for smoothing. Mine is just a simple tooth bar(Rankin) not one of those exotic, sharp shark tooth ones. I "bump & bleed" often enough with what I've got - don't need a sharpened one.
Nice tractor and loader. LA1153s are stout
/ Tooth bar options and. Advice? #14
Here is another newly installed but no rust on mine after 4 months and 100hrs use. Extremely happy with it!
/ Tooth bar options and. Advice? #15
Here is ours, after used for digging, scraping, raking, and any other ground, tree, and brush contact activities we could come up with for well over 2 years.
The brown and rust colored stuff is our clay.
/ Tooth bar options and. Advice? #16
i have one on my L2600...got mine from iowa farms,,was here in a day and a half...
2004 KENWORTH 10 WHEELER GRAIN TRUCK (A64278)
2004 KENWORTH 10...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
Toro UTV (A64194)
Toro UTV (A64194)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2014 KUBOTA R520ST WHEEL LOADER (A65053)
2014 KUBOTA R520ST...
2024 Texoma 16ft. T/A Equipment Trailer (A64194)
2024 Texoma 16ft...
