Buying Advice Kubota B5100E
/ Kubota B5100E #1
kzoocarpenter
I'm looking for a smaller tractor to work up some food plots on my land, maybe use a brush hog a couple times a year. I've come across a B5100E for sale. I'm not familiar with anything bigger than a garden tractor.... Anything I should know about this model? I read that the B6000 has a reverse pto. My biggest concern is can I easily get the right 3 pt implements for it, and are parts still easy to get. (I'm not sure of the year yet, guessing late 70's early 80's) Thanks!
/ Kubota B5100E #2
Get a newer tractor if you can afford it, finding parts might be hard on B5100.
/ Kubota B5100E #3
We have a B5100D (the 4wd variant). It has normal PTO shaft rotation. It's a great little tractor, but it comes with some limitations. At 12hp/10 at the PTO, and a 310# 3pt lift limit, you're not going to be able to lift very much in the way of implements or muscle a brush hog through tall grass or brush. It just barely manages a 40", 300# tiller. I suspect a 4' brush hog would be too much. To it's credit, it pulls a 4x6 fully loaded trailer like a champ through soft soil. It's about 36" wide, so it fits where almost no other diesel, 4wd tractor can go. So far, I have been able to get all the parts I need to keep it going with the exception of the front PTO (electric) drive shaft, which I intend to fix by remanufacturing myself. Personally, if I had to have only one tractor for small acreage farming or food plotting and chores on a limited budget, I'd be looking at it's bigger brother, the B7100. 4wd makes a big difference in utility as does a FEL (front end loader). Good luck, and let us know what you decide!
/ Kubota B5100E #5
I own a Yanmar 1110d which is basically the same size catagory as a B5100E except mine has 4wd. I would think that without 4wd that kubota would be limited for food plotting purposes. The B5100Es were usually set up for lawn care purposes. I like the suggestion for the bigger B7100D, they were very popular, and can be had fairly cheap.
/ Kubota B5100E #6
The b7100 is great i put power steering on mine. What a tank
(INOP) CUB CADET 1810 LAWNMOWER (A62131)
(INOP) CUB CADET...
CATERPILLAR 140 AWD MOTORGRADER (A63276)
CATERPILLAR 140...
CENTRAL PNEUMATIC 21 GALLON ELECT. AIR COMPRESSOR (A62131)
CENTRAL PNEUMATIC...
KJ 10' FORK EXTENSIONS (A62131)
KJ 10' FORK...
2026 Hillcrest Trailer 14166SPT 7 Ton T/A Partial Tilt Trailer (A61569)
2026 Hillcrest...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
