Boring out pin holes
/ Boring out pin holes #1
enterprisebbc
Ct
2008 CK35 Kioti
Can someone tell me if its ok to bore out the pin holes in an angle snow plow cylinder? I have an old Jeep plow 6' with 1.5, 10" that have a 1" pin hole. Now all I can find thats not to much $ is the same with a 5/8 pin hole. Or I can weld a cpuple of washers on the plow to accept the smaller pins. I have found exact replacement with the 1" but they are $100 apiece. Any ideas? What would you do?
/ Boring out pin holes #2
If you are talking about reducing sleeves for the pin hoes, TSC has adapter sleeve to reduce the pin hole, or make your own.
Is that Tractor Supply?
/ Boring out pin holes #5
I would try boring the cylinder holes. You may find the cylinder rod is hardened and can't be drilled, if so I would bush the snow plow mounts for a smaller pin.
I think welding washers on would not be enough support and quickly wear out.
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
John Deere 185 Hydro Riding Tractor Mower (A66285)
John Deere 185...
RHINO 127 - 7' OFFSET DISC HARROW (A64277)
RHINO 127 - 7'...
2019 Chevrolet Express Box Van, VIN # 1GB0GRFP7K1370206 (A65563)
2019 Chevrolet...
24in. Bucket w/ Teeth Excavator Attachment (A64194)
24in. Bucket w/...
